- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
5.0 do not have injector seats they sit directly into the lower intake yeah!!
@koda2000 your building the transmission to?
If so will you include it in your thread?
Your correct I had to do research and request upgrades knowing I was putting a new engine and blower on the x all in the end parts and labor was like $2500 worth it toTransmission shops basically don't ever do upgrades to the VB, or use virtually any upgrade part available. That is, they stick to rebuilding to stock conditions with their brand of rebuild parts.
Sonnax makes a ton of upgrade parts, plus many that are oversized to restore worn VB's. The oversized parts are not worth the trouble, because the tools cost is usually $300+ for one task. They also make a few other upgrade parts, for common or popular transmissions.
The 4R70W trans comes under that group, they make a ton of upgrade parts for the 4R, most for the VB, but lately some new large internal parts. I'm about to do the VC servicing in my white 98, I have all of those little Sonnax pieces/kits, and somewhere notes I made for the Jerry's Mod.
So a shop would never install any Sonnax parts, though many of them can save most used transmissions, lengthen their lives for much longer. Those same parts also remain in the VB after a future rebuild, so the costs are not lost, or duplicated.
If you ever get into a 4R valve body, replace(upgrade) the PR boost valve(the circuit). The pressure regulator is a wear item, and their are higher pressure valves and springs. Do not buy those(Sonnax started with those and still sells them). They came out a couple years ago, with a kit called a line boost kit. It progressively raises pressures at higher throttle, not idle or cruising. So get their replacement PR valve, and the line boost kit. Both are available from Rock Auto, for about $17 for one, and around $61 for the LB kit. I got their 4R70W Zip kit, which has everything you might want, minus the LB kit(did not exist when they created the Zip kit). Amazon has that for about $108 now.
Hi I think it's the plug wire shorting out. Look at it in the darkness.View attachment 176125 View attachment 176126
Here is a pic of the number 5 spark plug, and compression test on the cylinder. Engine was cold at the time. Spark plug has only been in there 3-4.000 miles.
