2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Will remove the valve body
Thanks for the advice. TSB 03-22-10, which applies to updating the separator plate applies to:
1995-2001 EXPLORER
2000-2002 EXPLORER SPORT
2001-2002 EXPLORER SPORT TRAC
1997-2001 MOUNTAINEER
1995-2002 RANGER
1996-1997 AEROSTAR
However, apparently the kit does not include a bonded separator plate for all models.
I have decided that loose valve body bolts increase the probability of separator plate gasket blow out so I will proceed with removing the valve body and installing the appropriate TSB kit. I hope that mine includes the bonded separator plate.
And the solenoid bracket being bent or broken is not unusual...In fact it is common...You can replace the bracket for little cost...
But please replace the seperator plate with the gaskets...Just retorquing them will break the gaskets and they will not seal...I know its a PITA to remove the vb just to replace the plate and gaskets but my previous attempt to retighten the vb bolts made matters worse...
1995-2001 EXPLORER
1995-2002 RANGER
1996-1997 AEROSTAR
