2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Valve body related torque specs
Today I received my ATSG 5R55E manual. The specified torque values for the screws/bolts related with the valve body repair/replacement are:
Separator plate-to-main control screws (T30):53-71 Lb-in
Solenoid clamps-to-main control screws (gold 10mm): 53-71 Lb-in
Main control assembly-to-case screws (10mm): 71-97 Lb-in
Manual valve detent spring screw (10mm): 71-97 Lb-in
Reverse servo cover-to-case bolts (10mm): 106-124 Lb-in
Fluid filter assembly-to-main control assembly screw (10mm): 71-97 Lb-in
Fluid pan-to-case screws (13mm): 115-133 Lb-in
