5R55E problem/question and ...HELP!!!
Hello everyone.
I've been lurking in the shadows of this site for about 2 weeks now. WOW!! I don't think I've seen this much useful information from such knowledgeable techs!
Now, on to the issue.
About 2 weeks ago, my buddy's Explorer Sportrac(has over 225,000 miles and has NEVER been serviced!!!) simply would not engage when shifted into the "D". However, it would engage and drive "fair" in manual mode; meaning it would shift 1-2, 2-3, 3-4(all were slow, sloppy and had the "flare"). No over drive below 40(odd) MPH. If attempted below 40(odd) MPH or under power/acceleration it would simple act as though it was in neutral(no gear/no gear engagement). Also, no engine braking in 1st gear. Reverse was another issue. It(reverse) is "there" but seems to only be partially engage, and not enough to back the truck up a slight incline!(Something likening to having the emergency brake partially engaged, you can "feel" the gear, but you're not going anyway and it stops "pulling" once you let off the accelerator...) Also some infrequent and mild shuttering in 1st only.
After reading virtually every page on the topic here and EVERY page in this diary, it seemed the best course of action was:
to drop the pan
perform the TSB(probably should have replaced the EPC as its out of spec at 22ohms, but the trans shops and dealership parts depts were closed)
replace the reverse servo o-rings and gasket(wanted the "D" rings but couldn't find them locally)
fresh filter and oil
THOROUGH CLEANING!!!
and go from there.
Did this yesterday morning. There were no metal flakes in the pan, however, the magnet looked like a tube of anti-seize erupted on it and the pan itself had a film of super fine particles but again, no flakes, chuncks or anything bigger than fine dust. VB was removed(found blown gasket in the reverse servo area and also near the first solenoid in the bank of four on the opposite end), cleaned, TSB installed to the letter(minus alignment tools, I used a couple of bolts and proper sized dowel pins) including new pressure relief valve, VB reinstalled and torqued to spec and sequence, filter and oil.
There was an improvement but didn't fix the actual issue of not being fully functional in "D" or "R". It still has virtually 0 pull when placed in "D" and "R" although there are definite signs of engagement. Reverse is better but still not fully engaged. Shifts between all gears are positive and solid(exception is (3-4 with VERY mild -250prm - flare) and overdrive will now engage at "low" speed. No shuttering in any gear and there is definite engine braking in manual 1st gear.
I don't have a line pressure gauge(nor access to one) and am working in the driveway of my townhouse with limited tools so my diagnostics are going to be limited and rudimentary.
I took it for a drive yesterday and manual operation is about 90%. It will operate in a version of "automatic" mode, less overdrive, if you have the overdrive turned off and initially shift it into 1st gears, then straight to "D" once you're rolling. Overdrive will engage, however, you have to turn it "on" once it shifts into high gear. If not, it acts like neutral. There is no downshift functionality so when you reach a certain speed, usually below 5 MPH, you have to started over in first or, it behaves as though it's in neutral. 1st and 2nd work regardless of the overdrive status. to the best of my knowledge and of what I have personally observed, the OD light has not flashed during this nor is the check engine light on.
With all that said, is it possible that the EPC is the cause or culprit? Has anyone seen, heard of, experienced this type of issue? Anything else it could be? If it is in "limp home" mode, can I clear the codes manually or will a shop have to clear them? (have heard of a method of clearing codes using the battery cables)
Thank you in advance for all your help and for maintaining a terrific site!!
Merry Christmas to all
p.s.
He's driving my Durango in the interim until I can get his truck fixed, then I have to work on mine...
