Someguywithatrans
Madison TN
2008 ford explorer
I have a 2008 ford explorer. Front cooler got clogged. I got a new case with the bore already reamed and sleeved. Used a 2005 ford mustang for parts. I used every single part except the torque converter. I used another torque converter i had for a 2007 explorer. Installed the transmission. Drove fine but there was a winning noise every morning or if its sit for a few hours. So does a whining noise when its cold. Guy brought it back because if the noise. I tore it down again. Replaced the pump and torque converter with other parts i believe to be good from a 2005 ford explorer. Oh and i installed a external cooler the 2nd time. Both times it makes a noise. Drives fine Though. I did however use dex/merc fluid both times. Then realising it takes mercon 5 i changed the fluid (as much as i can with just dropping the pan) and filled with mercon 5 and some additive to make dex/merc fluid preform as a merc 5. Does anyone have any other idea what it could be besides the pump, torque converter, or fluid. Looking for other ideas as to what it could be? Maybe the fluid inside the trans is still to thick. Any help would be greatly appreciated
974X4BLACKSPORT
Location
FL
hudson
BLACK 1997 SPORT 4 BY 4
Put a gauge on the hyd. test port and see what the pressure is doing when it is making the noise.
JK080
Transmission Moderator
Staff member
Moderator
North Ga
05 F250 6.0
If you end up having to pull the transmission again you may want to install a empty case just to support the starter to start the engine. If the noise is still there then its not a transmission problem.
Make sure the dowel pins are there too.
Someguywithatrans
Madison TN
2008 ford explorer
Im getting the car back on saturday. I figure out how to do that and ill give an uodate on my findings. And i have to take the trans down again ill install an empty care just for the the hell of it to see if it is the trans. I have a strong suspicion that it is the transmission but ill see. Thank you both for sharing your suggestions. I appreciate it.
L 5r55s rebuild Transmissions & Transfer Cases 12
N 5R55S always in reverse Transmissions & Transfer Cases 3
G 5r55s reverse servo apply lever and rod Transmissions & Transfer Cases 4
S 5R55S P0775 issue - lesson learned, damage done? Transmissions & Transfer Cases 6
I Weight of a 5R55S? Transmissions & Transfer Cases 6
R P0741....5r55s Transmissions & Transfer Cases 0
L 5r55s relearn. Transmissions & Transfer Cases 5
C Solved New 5R55S. The transmission slips. Transmissions & Transfer Cases 6
K 5R55S to rebuild or not Transmissions & Transfer Cases 21
A 5R55S drives forward just fine / Reverse only works if I do not press the gas Transmissions & Transfer Cases 17
D 2003 5r55s with 247k is tired... Transmissions & Transfer Cases 7
J 5R55S Servo Bore Fix Fail After Classic Symptoms Transmissions & Transfer Cases 6
domct203 Solved 5R55S servo cover popped off. Transmissions & Transfer Cases 52
J Hi All my first time dose rebuild kit for 5r55w fit 5r55s Transmissions & Transfer Cases 1
P 2006 5r55s trans swap Transmissions & Transfer Cases 1
B 5R55S Solenoid Pack??? Transmissions & Transfer Cases 2
J 5R55S Total fluid change-how to do? Transmissions & Transfer Cases 1
W 5r55s forward planet bearing help Transmissions & Transfer Cases 11
B Solved 5R55S adjustment tools. Transmissions & Transfer Cases 14
S 5R55S slow engagement after fluid and filter service Transmissions & Transfer Cases 20
K 5R55w to 5R55S swap Transmissions & Transfer Cases 6
D 5R55S Shift Reprogram Kit Question Transmissions & Transfer Cases 3
L 5r55s Double engagement or harsh reverse Transmissions & Transfer Cases 2
J Has someone swapped a 5r55w to a 5r55s? Transmissions & Transfer Cases 7
O [5R55S] No Reverse | Can't Take Off In 'D' Transmissions & Transfer Cases 9
A 5r55s/w no forward gears copper in fluid Transmissions & Transfer Cases 18
E 2004 Ford Explorer 5R55S shifting problems Transmissions & Transfer Cases 1
D Rebuilt 5R55S, please help me DECODE what the repair shop did. Transmissions & Transfer Cases 3
R 5r55s fluid Transmissions & Transfer Cases 0
E 2005 Explorer - 5R55S - Overdrive Planet sprag bearing fail Transmissions & Transfer Cases 1
D 5R55S o/d light blinking light Transmissions & Transfer Cases 2
R New member 5R55S replace the 5R55W? Transmissions & Transfer Cases 5
C Can anybody recommend a good transmission rebuild kit for the 5R55S? Transmissions & Transfer Cases 4
4pointslow Transmission Shift Flare/Slipping on 2-3 shift 5R55S 2004 Explorer Transmissions & Transfer Cases 19
D Midwest shops that can bore and sleeve the servos on 5R55S? Transmissions & Transfer Cases 1
08EddieCA New Front Pump 5R55S = must the trans be vertical to install the new pump Transmissions & Transfer Cases 5
D advice needed re. 5R55S parts swap . . . Transmissions & Transfer Cases 9
J 2005 Explorer 5R55S Loss of 2nd Gear Transmissions & Transfer Cases 8
H 5R55S 05 explorer wouldn't start. Transmissions & Transfer Cases 3
M 05 expl 5r55s diagnostics and repair. a self educating journey. Transmissions & Transfer Cases 20
D 5R55S Rebuild. Is the Ford factory kit adequate? Transmissions & Transfer Cases 2
08EddieCA Having reman 5R55s installed. Radiator, lines, cooler Transmissions & Transfer Cases 2
J 5r55s OD button Transmissions & Transfer Cases 13
G 5R55S Delayed Engagement Transmissions & Transfer Cases 5
G Swapped 5R55S for 5R55W, should I swap pcm as well? Transmissions & Transfer Cases 7
C 03 5r55s in an 07? Transmissions & Transfer Cases 2
4pointslow Filling the 5R55S Transmissions & Transfer Cases 8
H How many shifts from a 5R55S? Transmissions & Transfer Cases 3
4pointslow 5R55S pump replacement Transmissions & Transfer Cases 8
S broken od servo cover,5r55s 03 explorer Transmissions & Transfer Cases 1
Similar threads
