I have finally found some of the relevant parameters in the tune. I have way too much time on my hands now being unemployed, so I put it to good use.
Trans Pressure > Target slip time
This will firm up the shifts if the numbers in the table are reduced. It refers to the 1-2, 2-3, 3-4, 4-5 shifts.
Time to Delay Conv LK after 12 (23,34,45)
Converter lockup times were way too long in stock form. Stock settings were like 30 seconds until converter lock. I backed mine down to under 5 seconds.
Torque Calculation > Torque Table
I increased these values by over 25% to compensate for the extra power with the turbo. This made a huge difference in shifting.
Torque Calculation > Torque Table Friction
I also increased the table values here by about 25%.
Torque Limit > Auto Trans > Torque Converter Torque Limit
Stock was 280 in the entire table . I increased to 500 for my setup.
I also zeroed the Tip in torque control stuff for timing.
I'm still tweaking these parameters, but they seem to make the biggest changes in shifting.
