AltShiftKill
- April 30, 2010
- Grants Pass Oregon
- 2002 xlt
Okay first off a big thanks to every one on this site.
First thing I decided to do was paint the grey plastic trim black. I used Bondo restore black that i purchased at Wal-mart for $9.99. I chose this for a couple of different reasons, The Bondo is more like a dye than a paint so it does not scratch easily and it does not stick to your paint so it wipes off easily and you do not need to remove the trim or mask.
Second I removed the wheels to install the new 275/55/20 with black and silver Rims.
I had to remove the westin nerf bars because I hit a rock last summer and bent the brackets on the passenger side so the new wheels would not fit.
While the wheels were off i decided to paint the brake calipers. I bought a caliper painting kit from Schucks for $19.99. The kit came with caliper cleaner, masking tape brush and paint(I chose red). The caliper paint seems really durable and very shiny.
I wanted to stop right here because i noticed a bent dust cover the guys at les schwab told me that i needed a new wheel bearing up front and it was squeeling. I purchased a new hub but i wanted to bend this back and see if the noise stops.
I then started putting the wheels back on and noticed about a two inch lift from the new tires.
The camera is level with the 20's on the passenger side and stock 16's on the driver side
I bought a billet grill from ebay(used) $30 shipped and it intstalled in minutes by removing four plastic screws. I replaced these with Stainless steel hardware for less than a dollar
After installing the grill I decided that i wanted to paint it black along with the headlights. I bought fusion plastic paint for the headlights and flat black metal Krylon for the grill. I followed a forum on this sight to paint the headlamps and primed sanded and sprayed the grill
I am currently waiting on lower billet with hidden lights to be installed and i debadged everything.
