in the process of building a 92 explorer with a 4inch lift(i think it is) but running the D44 4wd TTb out of the fullsize broncos as well as the rear. Its comes to bout 8inches wider, 4in on each side. anyone interested?
do the front suspension drop brakets to the dana 35 ttb fit the dana 44 ttb?
yes the drop brackets for the 35 fit the 44.
yes i cut the shaft, but ironicaly its still full witdth to the T. the pass shaft is the only issue you have or atleast i did and steering. I would of rather stayed away from my custom shaft but since i was doing a garage build and didnt have a job to extremely fund myself i did what i could how i could and so far ive jumped, crawled, mudded, towed overloaded from stockton ca to prosser wa without any problem
i am lost a bit i guess.
your saying you used stock rbv lift brackets with the holes in the normal d35 location...no mods just bolted on??
the ranger has a different spacing on the pivots then a 150.
i am reading this your wms with stock rbv pivot hole locations is the same as it was in the f series??
your current width is dead on the same as fullsize?
if the 150 beams are in a similar plane of operation in a rbv as they were on a f series i dont understand the need to mod the intermediate shaft.
or are you over center for clearance reasons at ride height with maxed camber bushings, and its a travel issue and smashing the center u joint??
i remember dealing with a stock pivot location bolt in back 10 years ago or so and ending up using the 50 center setup on a 1 ton van trans slip yoke and reusing a d35 factory shaft....or maybe it was an aftermarket slipyoke....mark williams or something. it was 7 or 8 inches long i think. normal ones are like 5 to 6 iirc and it had to be longer. its a 1350 u joint application just like the d50 inner shaft. i cant remember the details but we were trying to get away from custom shafts. there was some problem and i just cant remember the details right now. seems cutting and resplining longside 10 bolt shafts was what happened at the end. i just cant remember, i looked around a bit at the club board as i am pretty sure it was a project there.
that said as long as a guy makes a extra shaft or two cutting and welding the shafts is fine by me....i am confident the neck down or ears will fail first if its welded right, so i dont have issue with that at all. i am more along the lines of bolt it and easy to find parts for mods as much as possible.
but since i can break d 60 shafts with a open diff and clapped out 6.5, i dont think i would be comfortable with custom d44 shafts. or any 44 shafts for that matter.
