crazyflights
- August 31, 2008
- St. Joseph, MO
- 97 1 ton Jeep
Please help, I have 97 Explorer thats is SOHC 4.0 was an automatic, I have swapped in a 5spd, it runs and drives but is throwing some codes, has hesitation and lack of power that it should. I did not swap the PCM, here are the codes, these all relate to tranny issues from what I researched P0708, P0743, P0750, P0755, P0760, P0765. But here are 2 other non related to tranny codes
---PO113 *Intake air temp sensor* & P0351 Ignition coil A Primary/secondary malfunction*
---My main question is I know i need to fix those 2 issues so those are not issues, but will the remaining 6 tanny codes, cause PCM to not allow it to run right and still cause issues?
Do I have to have PCM from 5spd SOHC explorer, and more than likley 97/98 right??
Please help, must having running good in less than 2 weeks for CCR09 trip.
