Corral Founder
- November 23, 2021
- NOVA
- 2021 Ford PIU
So I've had my 2021 PIU for a few weeks now and have been working to make it more suited to what I need it to do. One of the things that I found was sorely lacking was the ability to use the back as a "command post." The lack of lighting to the interior of the trunk space, as well as to the area under the shelter of the raised lift gate meant that you had to have a flashlight to be able to see anything at night.
So I found some 12/24v red and white LED lights on Amazon that I decided to mount on the interior trim panel of the lift gate. I bought two to be able to have one on either side of the panel. While these are so bright that one would be more than enough, I'm a "two is one and one is none" kind of person. Installation takes about 30-minutes if you take your time. Basically a tap into the 12-v ignition source installed and a "Y" harness is sent to the two lights.
You'll need some tools and a few raw supplies:
TOOLS
I built a "Y" section that then plugs into a single harness that connects to the tap-in connector and the ground. This allows trim panel removal later.
Then using a single wire I crimped on Powerpole connectors onto one end. The other end gets a ring terminal crimped onto the negative lead. The positive lead will go into the tap connector.
After building the wiring harneses, remove the interior trim panel from the lift gate.
The wiring harness that connects to the trunk has a 12v ignition source. I used the harness that connects to the lift gate side rather than the harness coming from the body. That way if I screwed up I could just replace the small harness. Look for the Green/Violet lead, peel back the insulation.
Tap in your wiring harness power lead to this wire.
Unscrew one of the screws on this panel and use that for your ground connection.
Next prep your lights. Crimp on power poles onto the ends of the leads for the lights. They are pretty short from the factory so this is why you will need a "Y" wiring harness.
Now flip the trim panel over and you will see two molded "dots" on either side that make a great reference point as your wire pass through. I drilled a pilot hole and then used a step drill to make a hole large enough to pass the lights' wiring harnesses through.
Mount your lights on the interior facing side of the panel. Connect your "Y" wiring harness to the lights, then connect that to your single wiring harness that connects to the tap-in connector. Put the panel back in place and violá! You will now have your own well-lit command station.
TOOLS
- 8mm socket and ratchet
- trim removal tool (optional)
- wire cutters
- wire stripper
- wire crimper
- I use Anderson Powerpole connectors for these kinds of things because I really like the way it allows me to build wiring harnesses and connectors that can be removed. The down side is you need a special crimper and the connectors are about $1/pair, but they are fantastic and useful so I HIGHLY recommend them.
- TC-1 Ratcheting crimper
- Anderson Powerpole connectors
- 3/8" drill bit
- drill
- Philips head screw driver
- 12-16 gauge Wire - I like to use this bonded pair wire that is red and black.
- Tap-connector
- 12/24v red and white LED lights
- crimp on ring terminal
