Aftermarket exhaust 4.0
4X4Bauer
Goffstown, New Hampshire
2002 Ford Explorer EB V6
You have the super 40 in right now...did you already run the super 10? I don't really want drone, i want more of a gurgle. my truck goes mainly offroad but i do drive it around town sometimes.
I've hear the super 10 and it's very loud. Super 40 will give you a good, loud sound with some drone. You need to remember that there is no switch for your exhaust- if you want it to be loud, it will ALWAYS be loud. You get used to it. There is no way to get the "nice and quiet gurgle in the low RPM's, loud muscle car in the highs" this does not exist. It will always be loud if you go with the super 10, and the super 40 is pretty close behind it. If you drive your car with no music or anything on the highway, you'll get sick of it. Putting on quiet to moderate music cancels out the drone though.
wbrudi28
West Islip, NY
2004 Explorer 4x4 XLT 4.0
i grabbed the delta 50 flow master, should be here in a few days. going to have the shop cut the cat out and replace the stock muffler...cant wait to hear it. ill post pics and a sound clip
wbrudi28
West Islip, NY
Just got the delta 50 series installed yesterday. Sounds great, just one problem.
The shop said there is an o2 sensor after the cat so he didn't take it out...how did you guys chop out your cats? I'm looking to go back and get the cat removed...some of you posted that there would be no problems/no 02 sensors to worry about :mad::mad::mad::mad: and when i go back with the solution ill also have him remove the resonator.
4X4Bauer
What year is your explorer? I have a 2002 Eddie Bauer Edition 4X4 V6, and after the main cat there are no O2 sensors. Go under your car and see for yourself if there are any wires or anything connecting to your exhaust. The cat of interest is the one right in front of your muffler, so check from there back.
wbrudi28
West Islip, NY
I have a 2004 v6 xlt 4x4. I don't readily see any o2s after it...I have a feeling he didn't want to deal with going from the 2.25" pipe to the ~3" at the secondary cat inlet. I'll double check tomorrow and see if he was BSing me...pretty sure he was. In the event he was, I may wait a few weeks to get the cat removed until the muffler breaks in fully to see what it will sound like over the long run.
You think removing the secondary cat directly before the muffler would make a difference in sound as well as power? Thanks for the quick response.
4X4Bauer
I didn't really notice a power difference, but if there was it might have give 2-3 HP at best. The main reason for me removing it was to clean up the sound of the exhaust a little, which it did. With the 40 series I have it sounds MUCH cleaner in the lower RPM's, but not too different higher up in the range. Now, if you changed the piping diameter, while also removing the cat and throwing in a free flowing muffler, you'd probably see a somewhat noticeable power increase. I'm no expert on this stuff, so google might be your best friend.
wbrudi28
West Islip, NY
Understood understood. Unfortunately I already purchased the 2.25" inlet/outlet 50 series. Noticed a little power increase, and a definite sound increase at lower RPMs. Anything above 2nd gear the sound difference isn't noticeable below 2k RPM. Ideally by removing the cat id hope it broadens the sound spectrum, the tone is pretty good as it sits.
Is it unheard of to taper the pipe from the ~3" before the cat to 2.25" for the muffler inlet? I would have gone larger, but I was worried about losing back pressure plus this dropped right in place of the stocker. Thanks.
Laugh-master
Alpena, MI
2002 Ford Explorer XLT
Just got my 40 series in and they recommended 2.25 offset in and 2.25 center out, is this correct? Will it be a slip for our do i need adapters?
K 02 ford explorer V8 aftermarket exhaust Modified 2002 - 2005 Explorers 21
S Will a RB lift kit interfere w/aftermarket exhaust?? Modified 2002 - 2005 Explorers 1
J Aftermarket bumper Modified 2002 - 2005 Explorers 2
D Any advice on aftermarket online wheel vendors/brands for 3rd gens? Modified 2002 - 2005 Explorers 12
X Aftermarket amp Modified 2002 - 2005 Explorers 0
C 2008 aftermarket tail light modification Modified 2002 - 2005 Explorers 4
firefly1246 Aftermarket Tune to fix v8 gas pedal Modified 2002 - 2005 Explorers 5
9 Aftermarket Radiator for the 4.0? Modified 2002 - 2005 Explorers 3
Mr_Fruffles Why are aftermarket MIA for 3rd gen explorers?! Modified 2002 - 2005 Explorers 3
M Aftermarket Halo headlights for 03' Explorer? Modified 2002 - 2005 Explorers 2
C Aftermarket stereo, now speakers out Modified 2002 - 2005 Explorers 4
D 2002 Aftermarket nerf bars...need help Modified 2002 - 2005 Explorers 7
S Aftermarket HU/need help with Fatory added amp/sub wiring Modified 2002 - 2005 Explorers 1
J Aftermarket fuel pump vs Factory fuel pump Modified 2002 - 2005 Explorers 4
2 New aftermarket stereo resets Modified 2002 - 2005 Explorers 2
G Aftermarket trans options Modified 2002 - 2005 Explorers 1
J Aftermarket head unit issue Modified 2002 - 2005 Explorers 3
A HELP! Aftermarket Stereo caused entire system not to work Modified 2002 - 2005 Explorers 2
Number4 Seat Swapping? Aftermarket Seats.....or from other vehicles Modified 2002 - 2005 Explorers 1
S changing the factory steering wheel to an aftermarket Modified 2002 - 2005 Explorers 6
T aftermarket fogs Modified 2002 - 2005 Explorers 4
D Aftermarket radio and bad reception Modified 2002 - 2005 Explorers 1
jayzx30188 Installing an aftermarket H.U.D on 04 xlt Modified 2002 - 2005 Explorers 3
A Tire Pressure Monitoring System On Aftermarket Wheels Modified 2002 - 2005 Explorers 3
D Aftermarket stereo? Modified 2002 - 2005 Explorers 15
B 02-05 aftermarket tail lights Modified 2002 - 2005 Explorers 30
J Let's see some PICS of 16-17" aftermarket wheels.. Modified 2002 - 2005 Explorers 3
A Aftermarket 17" wheels.. or 16's Post yours! Modified 2002 - 2005 Explorers 5
Kazer Aftermarket speakers Modified 2002 - 2005 Explorers 2
F Aftermarket control arms Modified 2002 - 2005 Explorers 5
lynchy wa aftermarket pop up sunroof Modified 2002 - 2005 Explorers 2
S aftermarket suspension long term? Modified 2002 - 2005 Explorers 0
D Any gen 3 aftermarket kits for diff or trans case swap? Modified 2002 - 2005 Explorers 2
M Aftermarket Brake Rotors?? Modified 2002 - 2005 Explorers 9
NHarris Suggestion for Aftermarket Addition to my explorer's exterior Modified 2002 - 2005 Explorers 32
0 I want a aftermarket hood Modified 2002 - 2005 Explorers 2
Rofocowboy84 Aftermarket Tranny Modified 2002 - 2005 Explorers 5
A Show me the aftermarket gauges on your 3rd gen Modified 2002 - 2005 Explorers 1
S Aftermarket Alarm with Door Keyless Entry?? Modified 2002 - 2005 Explorers 6
A Aftermarket Head Unit Kits Modified 2002 - 2005 Explorers 6
Z Things required for an aftermarket cam swap. Modified 2002 - 2005 Explorers 23
D aftermarket grills Modified 2002 - 2005 Explorers 3
R what aftermarket extended warranty to buy? Modified 2002 - 2005 Explorers 11
silver4x4 Aftermarket Coil pack Modified 2002 - 2005 Explorers 5
J Aftermarket Fog Grille? Modified 2002 - 2005 Explorers 3
R aftermarket wheel backspacing Modified 2002 - 2005 Explorers 1
T factory wheels with wheel spacers vs aftermarket wheels with less backspacing Modified 2002 - 2005 Explorers 23
9 Mountaineer aftermarket grill Modified 2002 - 2005 Explorers 5
J Aftermarket MAF housing.... Solution to MAF and air box removal Modified 2002 - 2005 Explorers 2
B Any issues with aftermarket headunits? Modified 2002 - 2005 Explorers 14
Similar threads
