jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
I'm looking forward to seeing some new dyno numbers.
I'm looking for a pump now. I have to wonder how a diaphragm pump will hold up thru one of our winters.
Pretty easy to do though, your right. Nozzle, pump, holding tank, and hobbs pressure switch. A bit of wiring, and its done. Its all about finding a good pump.
They come with everything including a pump.i would run their alcohol blend.i don't think you have to worry about it freezing,their should be enough alcohol in it to keep it from but i don't know how cold it gets.also how much you would need to keep from freezing.if the windshield fluid doesn't freeze it shouldn't freeze.think im going with a snow kit,pretty cheap.
