Kamaaina
- January 12, 2003
- Hawaii
- '96 XLT 2wd
Was under my '96 XLT and looking at the front suspension (2WD) and began to wonder.....if the lower control arm is suppose to move a little fore-and-aft (due to rubber bushings on lower control arm) to soak up road bumps wouldn't this tend to move the torsion bar fore-and-aft also? Is the torsion bar suppose to slide in the control arm socket? If not then maybe this is why the key pad on the rear gets so busted up. Just trying to figure out where this "give" is being taken up. Going to add some delrin strips over the keys on the rear and grease the front torsion socket in the LCA to see if that helps make the pads last longer. I'm open to opinions, suggestions, theories, 2-cents, whatever you got! Oh yeah, one more thing, what actually holds the torsion bar in place if it slips in the LCA socket and adjuster key?
