Wagonized
- January 16, 2005
- abbotsford bc
- 97 5.0 limited
all you need to do with your setup is bridge it and keep your sub output turned down. Listen for the smell of coil when ur playing it loud.
Its better to run too much power than not enough because now if you only want 400 watts rms out of that amp you know itll be clean power bc its only working half as hard as it needs to.
Bridge it and keep ur gain low or better way would be to set gain normally but keep your sub output on your deck set low.
