I want to rebuild my 5.0 Eddie Bauer into a daily driver/street rod. My main goal is make this as fast as I can from 0-60, but can be driven on the highway without the engine running at 3,000 RPM at 70MPH. So I am looking for people who have experience in changing out the gears in the differentials. As you may know this Explorer already has 3.73 but I am looking to get some real torque from this truck. I don't really believe going as high as 4.88 or 5.14 would be reasonable because this will still be a daily driver for fall and winter. I will not be taking this vehicle offroading, but like I said I am looking for very good torque with reasonable RPM range on the highway. I am looking at a 347 or 363 reverse dome crate motor (supercharger), and semi-auto performance 6 speed or a 4 speed performance auto transmission with O/D. Although a 5 speed would be a lot of fun and give me some more torque I don't want one in this vehicle.
Engine's HP rating (347) 450+
w/out supercharger (363) 500-550+
The torque I want is to be >550 ft. lbs.
Note: I know that you cannot just switch out the engine, transmission, and gears in a vehicle and then it's suddenly a street rod. Don't worry, I am an automotive student and when I graduate I will be starting this project.
Also,
If anyone has any suggestions on the type of engine I should replace my stock one with, I am all ears. I decided to go big or go home with the 363 reserve dome so I could supercharge it. But let's be serious, it's a very expensive switch. If you have had success with a different engine type such as a 347 with dome or flat pistons with higher compression ratios and good power and decent fuel economy I would love to hear your suggestions. This rebuild will not take place for at least 8 months and I have lots of time to perfect what I want to do.
So everyone please give me your thoughts, suggestions, and wisdom on anything you've done with these types of modifications.
Also,
