plumbago
- July 11, 2012
- 2013 XLT EcoBoost
Here is what you all are smelling!!!!!!! What you and everybody else is smelling under hard acceleration is the burning, (smoking) smell of the chopped strand fiberglass wrapping in parts of the mufflers. There is a lot of heat, and I mean a lot generated in the mufflers when you get on it, and it's driven hard....when this material gets hot enough its does not really burn as such, but get so hot it starts to more melt and smoke away, and it gives off the smell everyone has trouble describing....How do I know, well Mustangs have also had this problem, condition and smell for some time. After changing the axle back mufflers on our 2011 Mustang, the smell is gone. and after putting up with it for far too long, I dissected one of the mufflers, found the chopped strand fiberglass and burned some of it....there it was the very strong acrid smell described serveral ways....No question about it !!! It takes very little of this material to cause a terrific smell, which no doubt is drawn in to the vehicle, and it lingers in the vehicle for some time, from the rear recirculation vents...HAVAK AC vents.....So there it is, do what you will with it....best regards Plum
Thanks Milty for the words of support on my observations......
And for those that want to follow your hard running heatem up but good cure, I believe this will work also, but it just takes a little time, well, quite a little, and quite some gas money.....You could just replace the mufflers and rear axle back resonator/mufflers. Trouble here is it will cost you quite a bit to do this. I hesitate to post this, as it will sound crazy, but, it will speed up considerably the burn out method you have put forward....From the rear bottom side of the rear mufflers, where the exhaust pipe enters the muffler, measure 3" forward, and place a mark where the center of the entering exhaust pipe would be...Drill a 5/16" pilot hole upward through the bottom skin of the muffler and into and through the center of the hidden inlet pipe. Enlarge the hole to 1/2".....This will not adversely make the exhaust sound much louder, but what it will do is allow, under acceleration, more 02 to combust in the muffler and burn out the offending fiberglass packing sooner....keep in mind this might effect your warrantee, especially if Ford ever elects to fix the known problem.....best regards Plum
