I call my mustang the moose so I guess this 1998 ford explorer eddie bauer 5.0 awd thing is going to be called the moose knuckle. I'm bored as hell at work so figured why the hell not make a build page. Built by Cole's Custom Fab in Annville, Pennsylvania. EDIT: I posted this in the performance spot but I feel like I should've posted it here instead LOL
Engine: 5.0/302
331 stroker 4.030 kit from vigilante
7675 precision turbo
185cc AFR heads
EFI Compatible Hydraulic Roller Cam - Ford 351W & 302 H.O. 292/276
Skorpion 1.6 race series rockers
Ford performance rollers
Edelbrock intake upper/lower
flowkooler high flow water pump
melling high volume oil pump
350amp apex alternator
Canton racing oil pan
Fuel
60# injectors
340lph fuel pump
-8 braided nylon feed lines
-6 braided nylon return line
aeromotive fuel rails
aeromotive fuel pressure regulator
Transmission: 4R70W
I dropped it off with a wizard he cast a spell gave it back idk but it was expensive
FTI custom stall triple disc billet torque converter with lifetime warranty
Suspension:
lowering keys
lowering blocks
camber bolts
Interior:
ILXW-650 headunit
Audio:
Skar TX series door speakers
Skar ZVX-12v2
smart 3
big 3 upgrade
Engine: 5.0/302
185cc AFR heads
Fuel
60# injectors
340lph fuel pump
Transmission: 4R70W
Suspension:
lowering keys
lowering blocks
camber bolts
Interior:
ILXW-650 headunit
Audio:
Skar ZVX-12v2
smart 3
big 3 upgrade
