- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
the circuit breaker will work fine, I would not mount that cheapo fuse holder under a truck, the O rings wont last a year and the fuse will corrode away
If you notice the amp already has internal fuses, those usually blow first if there is an amp issue.
The stock speaker wires will work fine for you use, they can carry plenty of power and sound. I use them all the time at these power levels......way better then trying to wire through all 4 door boots.
Is that green wire the ground for this amp? Keep stereo grounds as short as possible and don't let them cross over any large power feed wires, this helps avoid noise interference in the stereo
I would not put the cargo panel back in until you have driven around a bunch and listened to many different types of music so you can tune the amp the way you like it before you bury it Also consider the air space around the amp, you do not want to install your factory plastic bits just to put the sound deadening material (factory) right up against the amp, give it some room to breathe if possible.
I know whenever I re do a stereo it can take quite a few trips and sounds before I have an amp and its settings "dialed in"
As soon as you think you have it sounding perfect in the shop you will hit the road and find something needs to change
