- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
Packing up to go back to San Diego tomorrow. Decided to do a backhoe flex test. Ford picking up a Ford.
Thats about the max flex from that tractor. It's the same on flat ground as anywhere else.Okay now flex the tractor!
Safe travels!!
I finally got around to getting the muffler replaced. The shop had Magna Flow in stock and they have a lifetime warranty. He also said the new FloMasters are Chinese garbage. It's a lot quieter, and there are at least three vibrations and/or rattles in different places that are now gone. I thought I might be having a potential driveline issue because it had a slight vibration in 3rd, but its gone. The only issue I see is it's a little fatter than the old muffler, and is about 1/4" below the frame rail. Might get creamed by a rock someday.
Thats wild, last year I had to replace my Flowmaster muffler (rusted out from inside, Explorer hardly ever saw snow), it was muffler from their Force II cat back long discontinued. I believe it had a lengthy 1 year warranty… Having dealt with Magnaflow and their lifetime warranty it was a no brainer to purchase a Magnaflow. Found a model similar in specs and had local muffler place install for about $50. magnaflow customer service was awesome when I needed replacement on Pathfinder many years back and they were helpful verifying specs etc.I finally got around to getting the muffler replaced. The shop had Magna Flow in stock and they have a lifetime warranty. He also said the new FloMasters are Chinese garbage. It's a lot quieter, and there are at least three vibrations and/or rattles in different places that are now gone. I thought I might be having a potential driveline issue because it had a slight vibration in 3rd, but its gone. The only issue I see is it's a little fatter than the old muffler, and is about 1/4" below the frame rail. Might get creamed by a rock someday.
Is this really Tom? I figured you would be dead by now. lol. Last time I heard from you, you said you had moved to Florida and would call me later... That was what, 15 years ago?Hi Brian, you still have that piece of crap? lol. It’s Fakree. Hope you’re doing well.
The lower mount is a Bronco/F100/F150 bushing so the upper rod end mount does most of the work. The lower bushing helps control road and tire vibrations. The front suspension has 14" coil over shocks, 43" long radius arms, and the 35" tires can drop below the body line. Its a very flexy suspension. I routinely bomb down Arizona desert dirt roads at higher speeds, and rock crawl where I use every bit of the suspension. When I go off roading, I tend to cover ground faster than most people, which makes the suspension work harder. There is a lot more movement and stress on that rod end than with a regular truck doing regular truck things. It's also a 3/4-16 x 3/4" bore, which is on the small side. Its the same size rod end as my steering so I don't have to carry a bunch of different spares.One has to ask, how a rod end on a track bar go bad? there's really no forward/back movement only up/down with a slight twist.
