Thanks, Kirby. I will leave it until it starts leaking or I can't stand the thought anymore of having a broken bolt on my Explorer.
I am still not happy with the brakes. I was cursing the soft pedal the whole time I was at Truckhaven. The pedal doesn't go to the floor, and it seems to stop on any type of terrain, but its soft and it bugs me. I was reading in this thread about brake master cylinders and such.
http://www.explorerforum.com/forums/showthread.php?t=424023&highlight=disc+brake+swap
I have posted in the thread before and wanted to know this (I don't like double posting, but if I can get an opinion, general consensus, or whatever, its worth it).
I have at the house, a 99 Explorer MC, and a 94 F-150 MC. Both have the same two-bolt mounting and bolt hole width:
Here is the break down
99 Explorer MC:
Cylinder Bore: 1.063" wide, 7-5/8" depth
Outer cylinder mounting surface: 1.571
94 F-150 MC:
Cylinder Bore: 1.056" wide, 8-5/16" depth
Outer cylinder mounting surface: 1.471
They are nearly the same width, but the F-150 MC has quite a bit more stroke. You can see in the picture, that it is taken up with the secondary piston (primary pistons are same length). 99 Explorer on the left, 94 F-150 on the right
A recap on what I am working with:
94 Explorer
1976 F-150 HP Dana 44, narrowed to Early Bronco width
T-Bird calipers with slotted/dimpled rotors
99 Explorer rear disc brakes
99 Explorer MC
94 Explorer booster
Everything is/was new at the time of the swap.
I was looking on some other off road and car forums about soft pedal feel after doing a disc brake swap, or upgrade. Several threads made mention of gutting the proportioning valve attached to the MC for the rear drum brakes and it working out for them. I am limited to a booster no larger than OEM due to my coil over hoops and the simple fact that I don't want to redo them. Winter (a engineer type genius guy who used to come out with us on runs before he got married, etc..) told me many years ago that the F-150 MC would help with soft pedal feel with a SAS.
Do you think the longer stroke of the F-150 MC will help with pedal firmness? And, I know it will fit onto my 94 Explorer booster, but will the pedal work with the longer stroke?
