- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
It's hard to tell from the picture, but if you're using high-misalignment spacers, do they allow enough movement so that you can just turn the shock bodies 90* from how they're positioned now? So the bolt would be perpendicular to the frame.
Can't do that because the reservoir lines would interfere with the shock hoops. They will fit as it, but I won't be able to get anything else back into the engine compartment. If I get 90* fittings at the shock, then everything should line up easier.
Zeek:
I went with 250/300 spring rates. Little stiffer than DB1's and lighter than Demon's. I thought it would be a good starting point.
