I worked on repairing the headliner today, but mostly I was out shopping for supplies. Also went to the DMV to do a partial application for salvage certificate. All I need now is a brake and light inspection, and have DMV check the VIN. After I get it finished, of course.
Purchased headliner fabric that is much lighter than the stock color. It was really all I could locate in the area that was not gray or black. It should be fine. I worked on repairing the headliner. The aluminum tape doesn't stick very well to the headliner. I ended up going around the entire edge and put a bunch on the back of it where it won't show, and if it comes unstuck, won't ruin the headliner. The tape that was on the front I sprayed with adhesive, which seemed to do the trick. I filled some of the holes in the material I no longer need (grab handle mounts, visor mounts, etc) with little cut-outs of cardboard, then backed it on both sides with the aluminum tape. It should keep the fabric smoother. I also repaired the holes around the dome lights with cardboard and a bunch of tape to make them square again, then I backed the push pin holes with tape on both sides because they are degraded. That is a very large headliner (9' long) so the plan is to cover it in four stages, starting with the rear quarter and working my way forward.
