I was messing with the steering and noticed some play in the steering intermediate shaft. Its at the slip joint. I have been using a cut-down XJ intermediate shaft for several years because it bolts right in and has U-joints instead of rag joints. I pulled the shaft to see if I could get the play out and noticed one of the U-joints is starting to fail. They are not replaceable. I kept my old rag joint shaft, which is still in very good condition, so I put it back for now. Some of the play is gone, along with a funny bump I could feel through the steering wheel from time to time while off-road. I might just leave it because if an ain't broke, why fix it?
How about we discuss 35" versus 37" tires?
I have been thinking of going to 37" tires for several years. I am not sure if the juice is worth the squeeze. The Explorer takes me nearly everywhere I want it to go in its current set up, and with the mods I am going to do probably this year listed in a previous post, it will be even more capable. The skid plates rarely make contact. Sasha the wonder dog is getting older and already has trouble jumping into the back seat. Larger diameter tires means more strain on the axles. 37's are very cool, but are they worth it?
To get 37" tires under my Explorer would require:
1) Moving the rear axle back 1" for the larger diameter tires to clear the body. 35's rub on the front edge of the rear fender opening when new. Sounds easy, but not. I could take care of it with a custom leaf pack, which I am planning on soon anyway. Would have to modify the driveshaft, but will have to do that with the Atlas install regardless. But, won't moving the rear axle back 1" partially negate the benefit of the larger diameter tires?
2) Explorer will have to be raised about an inch to clear the firewall and front fenders. Easy to do the rear with the new leaf pack and I can adjust the coil overs in the front. But, it will change the drag link and track bar angles, and the caster, and possibly cause binding issues with my front driveshaft at full droop. Will also need to move my bumps down. It will also change the center of gravity, and its very stable in its current configuration. I mean crazy stable, like a weeble wobble.
3) Move the spare tire mount over to clear the right-side tail light, which might not clear the gas can, which would make me redo a bunch of stuff with the rear bumper.
4) New tires and wheels will cost me around $2500.00. I can sell my 35's and wheels for about $1000.
I think I just talked myself out of it, but lets discuss anyways.
