BigDakota
- November 23, 2004
- Bismarck ND
- 2001 Explorer SportTrac
Shelbygt , you can scrape up some more bucks and find a another head(which would be good) or do the best with what you got. You could get some valve grinding paste, pull the valve spring off, spin that valve around in its seat with some paste on it and make sure it sits nice again. You could try to smooth that weld near the valve seat with a small dremmel grinder. ..Before you mount that head,get some Copper spray a gasket and put a layer on the block and a layer on the head before you place the head gasket down.Hopefully you can get some more good miles out of the Ex.
The Spray a Gasket is good stuff, it can help seal if there are some imperfections.
You can google it and research it.I have used the spray a gasket on different vehicles and have had good results.
