Blueka's "Pickle" Registry.... | Page 25 | Ford Explorer Forums
yeah... I said for long enough that I wouldn't do it... then I priced out the superlift kit and at $2500 I decided that I could SAS it for less... so...I am.. slowly gathering parts and getting stuff done as time n funds allow... It'll get there, hopefully by summer
Si
I'm also putting in a 4406, not sure if I'm going electric or manual yet, but, that's the plan..
Si
I've got both styles of 4406 here already, I'm going to build the axles up over the winter, so they're done and out of the way, and I'm going to try to get the elec case fitted and working, long slow process... but, I always try to take pictures and update as much as possible..
Si
I bought this last month, was hoping to put it on this weekend, hidden behind the bumper, but, it probably won't happen...
I'll be using this thread as a guide Clicky
Si
Will you be doing this sort of mod to go with it.
[thread=228245] Click Me! :)[/thread]
Did a little bit more work on my rear axle set up tonight... I smashed my finger to bits last week whilst taking apart the Explorer 8.8.. it's taken a week to get to the point where my finger doesn't hurt so bad and I can finally carry on...
So, tonight, I finally got both axles stripped and got the Explorer discs bolted up on the full sized 8.8
Si
I was tired of looking at Pickle covered in winter road dirt n salt... so I decided to treat her to a once over at the car wash...
I jetwashed the engine bay, all up underneath, under the rockers, inside the flares, frame rails, etc... then gave the inside a quick blow, vac and shine up... then waxed the outside...
Si
Si
Are those 3rd gen rims?
Why did you choose those over the stockers?
They were on the 02 sport at the side of my house 3/4 had winter tires in the correct size... I'm broke... so I only had to buy 1 tire
Si
Looking good , and i kinda dont mind the wheels
I'm not overly enthused by them, but, they're serving a purpose for now. till I get my 37s on.. :D
Si
Well, I've committed myself to the lift now... haha... I've got the master install kit, locker and 5.13s for the rear... the fronts will be ordered next month. Then I'll just need some odds n ends and the lot can go in... exciting times
Si
Well, I did a little more for my SAS and got my D44 narrowed 6" so that I can make it work, I've also picked up some wheel adapters for the back and I'm almost ready to get my rear axle built up, just need to order my truss.
Si
Test fitted the wheel spacers/adapters today... and the 37s... obviously needs lift, but, it sits nice n wide..
Also got some new beauty products from Jon.. (Turdle)
Before
After
Si
