Blueka's Elite Registry | Page 5 | Ford Explorer Forums
Well.... 2 years later... where are we?
Well... finally found a shop willing to do my chains, so my Explorer went in a week or so ago...
Almost done
Si
Yeeyeee
it surprises me that there are no SOHC out that way to just swap in.
Well, finally got her back beginning October. After the initial run, the timing jumped and the engine had to get pulled again, all the valves were bent. So, using the head off the old engine,it was fixed again and reinstalled.
Now I've got to install the lift kit and get some new tyres. Also need a few other bits and pieces
Si
Glad to see her back in your hands and on the road again. :chug:
What was the verdict as to why it went bad after the shop initially did the work?
Well, now that Christmas is out of the way, I've finally got around to installing new spot lights on the front. They're from rigid. I've had them about 3yrs or so.
And I can also finally start installing the lift
Si
😡😡😡 got all the front torn down, school boy error, didn't check all the boxes properly and it turns out there's 2 bags of fittings/ hardware missing. I've contacted rough country and hopefully they can get them out to me asap.
So I'm currently stuck.
Si
Just hanging out there, it's ready for surgery.
How many miles are on the engine, the oil pump? I did all my big stuff when I bought my 99, the oil pump too. Check for any leaks and clean things well, now that it's all open and easy to work on.
Engine was a good used 88k miles. So I had all new chains n stuff, water pump etc. Didn't bother with the oil pump.
Si
That's a good engine, just a baby.
Mine had 75,450 when I got it, now it's at 152k and needing the trans rebuilt.
Turns out they did send the parts. Anyhoo. Managed to get the new, re-geared front diff in, although I did wreck one of the bolts and retaining nuts
Si
Did a little more after work tonight, got the front diff in and all bolted up tight, then installed the bottom arm relocation brackets front and rear
Si
Torsion bar relocation brackets are in after slight modification. My Explorer uses a different style of damper, so I had to cut the RC bracket to fit.
Si
Finally made a bit of progress today. It took all day but managed to get the old factory bushings out of the lower arms and get new polyurethane ones installed. Then I fought with it some more and got the arms back on
Si
