- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
yeah slow down, deep breath and start looking at fixing the issues you have right now, not changing it more, because that will just bring new issues.
Vibrations = tires, start there. I want to see 0 on the static balance machine after the weights, then add some equal or similar continual balancer.
drivelines, should be balanced and have the proper amount of overlap at the slip yokes. New U joints, CV assemblies if required.
You should have good mileage if you have the correct gearing for your tire size, which I dont believe you do? Tire pressure is a good place to start as well.
Lifted trucks dont drive like lowered trucks, but IMO once you get them dialed in they drive FAR better.
AWD is not going to help your mileage!
Why are you tearing through wheel bearings? this points to improper preload/torque, bad spindle, or most common, tire out of balance.
