Oh I agree, labor would of been an arm & leg (I'm guessing a couple hundred? I don't know). But your right, the cherry was getting my hands dirty. Not only will I never go to the shop for a brake service but this has given me the confidence to do other repairs just knowing I overcame this (had to get creative at times) and knowing it will be done right or thoroughly.
That long post that cleared out on me, I mentioned the few things that I think went wrong and I refered to you and your past suggestion. I'll try to remember how it went…
I think a few of the things that could of caused the leak with the 1st set of remans are more of a combination of minor things. 1 is the suggestion from swshawaii, to torque the banjo bolt to spec. I admit I didn't because of fear of snapping the banjo bolt again. I did torque it down on this 2nd set, mainly because the one caliper didn't even have grooves (completely flat) so I figured this would leak for sure and I'd send it back anyways. So I had new banjo bolts and I thought I was going to snap these as well but it finally clicked. 2 is when I broke the old banjo bolt I used the crush washers that were sent with the remans and had to buy new ones when I got the new bolts. These washers were the right spec for the bolts but seemed thinner (using the thickest ones) than the reman washers but I didn't have a way to compare. When I got the 2nd set of remans the washers were same od but night and day on thickness and 3 the banjo fitting was rusty (around where the original washer sat) so it's possible the washer didn't seat exactly were the original did and overlapped on the formed rust. With one of the calipers in the 2set of remans being completely flat (no grooves), this leads me to believe is was probably a combination of 1 of the 3 above because that's the only changes I made besides a new caliper (which could of still been the issue but)
I'll list all the parts later that I used with pn since this was a thread of opinions on brake parts/brands also
