- February 18, 2015
- Phoenix Az
- 1991 aerostar
I assume this was for another thread?Junk lol
Just making sure they aren’t a the early fms “headers”
The truck at the junkyard has 187k miles. Is the wear on the head consistent with that amount of miles? I wouldn't personally call 187k high milage. My truck has 107k.from a worn, high mile motor.
It isn't the total number of miles, but how it was maintained and cared for during those miles. The oven cleaner won't hurt anything if gets all over the cylinder head. For the exhaust ports, stand the head up on edge and fill each port, then let it sit for awhile. I've cleaned used pistons, and a the vgt wheel of a turbo with oven cleaner.The truck at the junkyard has 187k miles. Is the wear on the head consistent with that amount of miles? I wouldn't personally call 187k high milage. My truck has 107k.
Is there anywhere that I should avoid spraying the oven cleaner?
I removed that rocker arm myself at the salvage yard.It is missing one rocker arm??
Yeah, but it's nice to look at.lol hahahahaha it’s a 5.0 head… run it! Hahahaha she’s fine
It’s the v6 heads that crack and lose valve seats after 250k miles
close up pictures of each combustion chamber
If you ever have a head gasket failure, that would be the spot. If I had my heart set on using that head, I'd clean the rust off the metal around the chipped area, then build it up with JB Weld. It's not a high stress area, it just needs enough material so the gasket holds
