- January 14, 2001
- Fresno CA
- 86 ranger no more
- Callsign
- KK6TDL
go 5.13 gears. I have 4.88 wish I would have gone 5.13 instead.
Doubler isn't low enough?:
5.13's it is then, also going to Kartek to check out shocks as I'm going to be in Los Chico's Taco's anyway! WOW my wife is pissed i was not home for V-day oh well.
You better bring her home something nice... One thing I have learned, the wife is cool with the truck as long as she gets her attention.![]()
Well this is what I have so far.
1. 2 Dana 44 hp front axles w/ radius arms and steering links
2. Ford 9” rear axle- to be sent to currie ent. For disk brakes and trussing
3. BW 1354 manual transfer case
4.
5.
6.
7.
8.
9.
10.
1. Seems like 14" works well for alot of people.
2. When I link mine I am using 2.5" currie johny joints with the 1.25" shanks. Pretty beefy.
3. Do a 3 link with a panhard. Look at www.trail-gear.com and see how they do there rear link setup do something like that.
4. When I cage mine I will probably use 1.5" .134 wall. The smaller siz will make it fit better and the thicker wall will make it stronger.
5. The 9" wont spin a housing like an 8.8 will. If you plan on going high pinion. Check out www.truehi9.com Much beefier then the currie unit.
6. If you have 7" between the gastank and the tcase a doubler would fit. I like my doubler alot. An atlas would be sweet but it also cost 4 times as much.
7. Id do my best to keep the truck as close to street legal as possible. Lots f trails start in one area and finish far from the trailers. Being street legal is a huge advantage. Even in truckhaven I have used the highway many times to get back to camp.
8. That new warn one is huge. I would get like a 9000lb one and call it good. I have the warn XP I still need to finis wiring it before I can use it.
Also what kind of shape is the drivers door in? My dad could use one for his 75 f250. Maybe some trim pieces as well if they are good. Also your spare dana 44 you have I bet you could get a nice tiki out of rangerX for it.![]()
ive gotten some stuff from ballistic and even though they have some pretty trick stuff, I wasnt to impressed with the quality.
