I will keep looking thanks
this conversion seems like its pretty simple, is it actually just bolt on the two mounts and mount the shock? i feel like i'm definitely missing a step?
I think I might just build my own brackets it does't look like that much trouble. it would be nice to be able to still order this kit but we do what we must do.
The upper is a bit tricky. It has a curved back at the top, and you still need the machined spacer over it.
The lower has to have the inside welds ground so they don't interfere with the mount sitting flush against the lca. Make sure the mount tabs are high enough so the shock can move freely and not touch the bracket.
It is so simple that there was never really a need to do a photo step by step how to. Lower bracket uses the 2 existing shock mount holes, and you drill a 3rd hole on the side of the LCA. 3 bolts & done. Upper is bolted to the top by placing the machined spacer on top of the bracket, and then the bolt/nut. With the back of the mount sitting flush to the shock tower, you mark & drill the 2 bolt holes. Bolt it on and done. Weld the braces half on the frame rail, and half on the tower. Plenty of pics floating around for that.It looks like you were one of the first to do this conversion. Would you mind answering a few questions?
1) Did you, or anyone else that you know of, post step-by-step photos of this RCD conversion? I've skimmed through the 29 pages of the conversion thread mentioned earlier, but only seen photos of completed trucks.
2) What company does RCD refer to?
3) Did you use the conversion to raise the ride height (lift) your truck too?
Thanks very much,
Lonnie
You're not really changing the "suspension dynamics" at all, just the method of suspending the vehicle. Geometry is the exact same and thus can be aligned the same as stock. I could potentially reproduce these brackets, or a variation of them, if someone could supply me with existing ones.
