Cybergasm's 1991 Explorer XLT 4x4 | Page 9 | Ford Explorer Forums
Welp a day and a dollar short but finally got the F-150 coil spacers installed tonight :D
Although while in the process of doing this I came across this when I had to remove the passenger side Caliper in order to get the Beam to drop enough to get the Spacer in on that side.
let just say those were replaced in short order :D
Next up Time to get some Radius Arms in this truck.:D
and then i found this..........
it been doing this for awhile but did not realize how bad it was getting. It actually wearing a groove in the axle.:( Now to figure out what to do about it.
grind out the hole. enlarge the window. the opening the axle goes through. take a cut off wheel to it and trim it back and down. its something you gotta do if your getting good travel out of a ttb :thumbsup:
hmmm good excuse to break out the Cordless grinder i just bought last night too :D
I'd eyeball a few things and maybe even measure your wheelbase on both sides. It shouldn't be rubbing that high up on the window. It's making me think you may have a bent beam or bracket
I clearanced mine at the bottom inner corner and was good to go. you can see a faint outline on my axle and that was it.
So a question about your powertank:
How does the co2 do when running in your tires
Not really sure about that i just got the Tank filled yesterday and got the Regulator for it. But I did test it yesterday on the Van Tires. And ran around town for a bit and did not noticed any difference.
Might wanna ask Stic-o or DB1(the previous owner of my Tank) or maybe they will chime in here about the effects if any.
i doubt cyber has anything broken or bent. good idea to look though. danny your kit probably deasont rub as much cause its a very well thought out "kit", cyber just has a drop bracket kit which i think would cause more rubbing. and i think autofab already clearances the houseing a little bit.
So what regulator did you go with?
C02 acts just like regular compressed air in tires. One nice thing about a C02 set-up is that it fills your tires really fast.
As much as I wanted to keep the Powertank, is was not cost effective for me to have it. The only place that can fill it was a half hour away and had to be dropped off so that's 2 round trips I had to make. On top of that, they raised their rates to fill tanks.
Anyways, i'm glad the PT went to a good home just remember to charge people 5 bucks to air up their tires at the end of a run:p:
I went with a Uni-Weld CO2 Regulator they had at the Airgas store for 66.00 it's adjustable to 120psi and is working perfectly. And they filled the tank for 13.00. Just had to buy a coupler and a 90 degree fitting for the Regulator. Hooked up a Impact Gun to it today and changed a tire on my Van and it worked great. Definitely Liking this Powertank :D
OMG what a weekend right now i am in the process of installing the Reworked Superlift Extended RA's on the X. Man this was a bigger job than i anticipated. Progress is slow at best working with what i have.
got one side done and a couple hours in the AM and i should have the other side done too.
so far with the one side done it's looking like a picked up a couple inches in the lift dept. SInce not only am i installing the Arms but also installing new springs too :D along with the F-150 Spacers that i previously put in. might need to drop the axle pivots into the 5.5 inch holes now to get the camber somewhat corrected as it sits now.
Photos and such tommorrow ;)
So are you gonna be close to 10 inches of lift now? With the springs, spacers, and body lift? That's not even including the 35s! That's waaay too tall IMO, don't want to see you roll.
there is no differance. I've used it to put added air in the 150 and the trailer.
The one thing that sucks about the PT is the tank changes size. When you put in it's mount at room temp it fits, and then you use it and the tank gets super cold. When you go to put it back in the mount it dosn't fit anymore. The tank has gotten smaller. It really a pain, because it will keep falling out of the mount until it reaches room temp again.:rolleyes:
yeah getting close there thinking right now right around 8ish inches accounting for everything.
MIght need a little extra boost in the out back also ;) think the SOA is coming soon.
Got both Arms on the truck now. Right now i am figuring out the Shock mountings on the Arms since nothing came with them for that.
Now that everything is done. Here are the long awaited pics :D
11 Something PM Sunday night and one side Almost done.:rolleyes:
Working on the Driver Side Monday Morning;)
Alittle Redneck engineering to get the Nut on the Radius Arm
The ever growing pile o parts:D
With both arms done and shocks installed tried to drive it and had alittle problem
Yeah just bit too much lift in the Front So i ended up dumping the Coil Spacers and had to drop the Axle Pivots into the lower holes to get the Camber somewhat back to sanity.
Other than that everything came out great and i am stoked that i got these on the truck. Was getting a little tired of looking at these things laying around in the Van :rolleyes:
oh yea the passenger side axle looks better these days too.
but not by much tho i think.:dunno:
One Week later or so.......
Radius Arms are doing good in there new home.:D
But the New Pro Comp Coil Springs are stiff like the previous Owner said or may i just need to get used to them. :dunno:
damn i wanna wheel this thing now.:(
And found out i need to redo the shock mounts tho not liking the way i have them now. Need to figure out a better mouse trap for them. :scratch:
Hmmm did not realized how much has changed on my truck in 2 years
Update first Post ;)
Hmmm forgot to post this the other day,
I was in a local burger joint eating and there 3 younger guys in there eating they finish and leave as there crossing the parking lot they see my X and could not stop checking it out:D
Spy Photo :thumbsup:
think that Ranger was only a 2wd :rangertan:
If I seen a lifted ex round here I'd be checkin it out too :thumbsup: I mean after all they do look better than a lifted Heep! :D
