She is finally running smooth again. I had to take it into a shop and I asked them to run the gamete on it and check everything out. All my cylinders read the same on a compression check. I have spark to all the cylinders. The problem was number 5 and 6 had clogged injectors. They cleaned them and put a bottle of injector cleaner in the truck and all is good. The more I drive it the better is runs.
Now here is my list before I hit the trail:
I need a cowl induction hood, where do you get them, I prefer steel???
My engine cage will not clear unless I get a hood.
-Mount shock reservoirs
-Front ARB is not engaging, figure that out
-Mount ARB compressor
-Mount Radiator overflow
-Mount Rear Shocks
-Purchase and install bilstien coil over spacers
-Mount new headlights and clear corners
-Install winch power cables
-Reinstall front bumper
-Install and hook up winch
-Install ARB switches on Dash
-Change bolt pattern on spare tire mount
-Purchase lug nuts and install wheel spacers
-Notch trans cross member
-Clearance front drive shaft flange
-Install correct pinion yoke
-Fab air cleaner mount
That should be enough to hit the trail
