Engine swap: v6 to v8 | Ford Explorer Forums
Xplorer95
Lexington, SC
1995 XLT
I have a '95 four door xlt 4x4 (heavy). The v6 is old and SLOW. What would it take to drop a (built?) 5.0L into it? And how much hp would it take to get this heavy beast into the 13s???
it would require a 5.0 and a supercharger.
how hard would this be? what special parts would be needed?
It's not easy.
If you want to do it, you will want a 5.0 and wiring harness out of preferably a 94 Mustang ($1300) a built AOD transmission ($1000), and a supercharger ($3000).
Then lower the truck a little ($?) for safety and that's about as cheap as you can do it.
What about computer stuff and wiring harness? Could I keep all the stock computer and wiring harness stuff if I go to carb?
BTW, why was this topic "MOVED"?
One more thing: What about the transfer case and the axle(s)? How would they hold up? Will an AOD out of a mustang or something else bolt up the the transfer case easily?
carb would definatly be easier if you can fit it under the hood. however of you go carb how much more power are you really gonna make. there is also the fact the fact that the tranny is electronicly controlled.
You should find a totaled 95-? 5.0 explorer. All the parts you would need and everything would just be a swap, bolt in . No moding at all. Very simple. You just have to find a totaled explorer.
I'm with 351 here. You could do this in a weekend easily if you had a donor.
But a stock 5.0 explorer doesnt run anything close to 13's Will take some work. OK a lot of work. Carbing would save a lot of trouble.
XLT_66 ran 13s in his 5.0L.
Once you have the basics done, then you can start with the power makers. Cam, supercharger, intake, twin turbos,ect.....
The swap will eat up a lot of you money to in the begining, then slowly get stuff and bolt it on.
Carbs are for muscle cars, EFI is the way to go.
to run a 13.9 you would need (roughly) 400hp at the crank or 320hp at the wheels. not at all hard to do with a 5 liter, but more work than just stabbing in a stock 5.0 and slapping a 6psi blower on it.
thanks James, that was my point
I ran a 13.92 at 101 at Seguine.
Port 'N' Polished Heads
Upper and Lower Intakes are Port Matched
E-Cam
1.6 Roller Rockers
4.10s
Headers w/ 3" exaust
Cold Air
upgraded MAS and TB
Drag Radials
Apten Chip retuned by Motion Dynamics in Austin
Fresh Zaino
125 Shot of NX POWER!!!
Removed back seat
1/4 tank of gas
and a 1 mph tailwind
Hey, it weighs a ****load but hey, its in the 13s.
With your truck the easiest V8 swap would be out of a 96-01 Explorer, swap in the computer, wiring harness, transmission, everything is essentially bolt in since you have a 2nd gen already.
hahahaha sure it can be done in a weekend with the donor sitting next to your truck.
That would be a hell of a weekend!!
Also dont forget about the $10K its gonna cost to get STARTED. :)
This thread makes it sound WAY to easy. Yes it is true the 5.0L conversion would be easier from a second gen ex to a second gen x, but there are still plenty of parts to replace, plenty of $$$ to spend, EXTENSIVE wiring to do, and custom parts to buy.
My point is this. This guy asked:
How do I get a 5.0L into the truck and run 13's in the 1/.4 mile (basically)
The answers are : No problem, can be done in a weekend.
Am I the only one that sees a problem with this?
First off whos gonna do the work? Because if you are asking this question in this manner it is not like you do engine conversions often.
Also dont forget about driveshafts, exhaust, wiring, re-arranging things in the engine bay, emissions, replacement of parts (such as clutch), fluids, shift linkage, pedals, wiring etc etc etc.
There is ALOT more to it then parking two trucks next to each other and moving things over.
A 5.0L conversion is not simple, period.
Alot of it depends on who you are and how familiar you are with doing things like this, this thread makes it sound like its no problem, anyone can do it, easy.
You must have the tools, you must have the time and $$$, and you must locate the donor and all other conversion parts before you ever turn a wrench.
Look to spend 10K or more plus many many hours of wrench turning and frustration.
Yes it is easier from secoind gen to second gen. Yes most of the parts will botl in no problem, b ut yes there IS ALOT more to consider........
Research is the KEY.
Educate yourself about what problems will you run into. what parts work with what, what donor you need to find, how much the donor should cost, what parts NEED to be replaced, etc etc etc.......
Heh. Yeah I had a problem with that statement, but I thought he was joking about a 302 conversion taking "1 weekend"...
Well I stand corrected. It will take $10,000 and a couple months to do this. So don't even try it.
