TestPoint
- August 21, 2009
- Ellijay
- '00 5.0 in an '82 Volvo
Oh! The joy of . . . .
. . . . kerosene!
It was 32 this afternoon in the garage but a few minutes of the Ready Heater fixed that.
I checked the resistance of the injector coils and got about 20 ohms. With power on the red lead I grounded the lead from the PCM on the two injectors I could get to under the manifold. No click. I consider that a pretty convincing report on the status of the injectors. So o o o o o o . . . .
I have a message into the Orlando Injector Doctor about reworking mine vs just buying their in-stock set. Sure as I send them mine one or two will not come up to specs in the spray/flow test. The rail has the original modulator on it. Everything on this engine is undisturbed as Ford built it in 2000, except, of course, all those things I am in the process of screwing up.
You make a very good point about the PCM expecting 65psi because of the tank mounted regulator. I added the external pressure regulator because putting the Ford version in the tank was going to be difficult and I had a return line to work with. The vacuum connection will go away. And I thought I was being so smart adding that.
I can get the intake parts sand blasted and clear coated now. At least it will be pretty even if it never runs.
. . . . kerosene!
