Hey I'm gonna eventually do this swap most likely over this summer. Do you have any idea on what the whole total cost was?
i was going to save and get it brand new from fordparts.com unless i can find a good condition one for a good price and rebuild it.
im reserching alot of the parts you mention it the second post on page one and making a spreadsheet now. mines a 99 xlt 4door. the trans i have now is the 4r55e i believe and its starting to go ive been wanted to do the swap for awhile and now i have a solid reason to do it i know im going to need the m5r1 hd . my friend is helping me hes on the site as mr. truckles we're going to work on gathering parts in a few weeks. any advice as to where to get parts and also tips on how to do the actual swap?
Bones! Are you still enjoying the BW 1354 swap? I kept my 4405 and it has been fun but I really miss being able to do cookies in the snow and mud... what did you snag your 1354m out of?
and you can just give ford $150 bucks to reflash your pcm to manual settings or spend $600 and buy the delta force commando tuning kit and delete the auto trans from your pcm
Ok, I need a little clarification or update on this if possible. If I am reading this right, in order to put the 1354 manual t-case in a Sport, I'd need some sort of spacer or shortened rear driveshaft?I finally got around to installing my BW1354. The BW1354 is 1" shorter than the BW4405 and your rear driveshaft (at least 2-door) will definitely not fit. It's probably best to get your DS lengthened at a shop, but I used the Steeda 17mm (11/16") Driveshaft Spacer 555-7707 (marketed for Mustang 8.8s). JEGS also makes a version of the spacer..
Thanks for the speedy reply!! Hmm that's definitely something to consider. May just have to go the electronic t-case route then
