- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Read the list of items in this thread which suggest poor mileage, and then compare those to a typical later sedan. Those cars don't have 4500+ lbs, 4WD transmissions, four cats, huge frontal areas, and hauling a lot more stuff regularly.
There's things you can do, but removing 1000-1500 lbs of constant weight isn't one of them. Most of these we discuss here have 4WD or AWD, they have probably double the HP loss due to the drivetrain as 2WD cars with 2WD. A lot of people drive manual trans vehicles, so these 15mpg SUV's have glaring fuel use issues.
They aren't as efficient as vehicles 10 years newer, which gained a lot of advantages with emissions changes, and variable valve timing becoming more common. Get an engine/trans from a brand new vehicle and swap that in, there would be a big improvement there. But nobody is going to do that with such an old vehicle, given it's current value.
