Your thread was merged with this one on the same topic. Make sure you get the clips as well. 2011-2019 Ford Pillar Molding BB5Z-7803145-AA | Auto Nation Ford White Bear LakeThanks guys,
Its BB5Z-7803145-AA
I was able to find an aftermarket solution that includes the full kit, we will see how that works out, as aftermarket parts can be a crapshoot but the Ford part failed, so... Looks like install is trivial per YouTube videos, unscrew old lower, screw in new lower, install snaps and apply some adhesive, install upper. The kit includes weatherstripping on the lower panel.So, my research says I need
Pillar Molding - Ford (BB5Z-7803144-AA)
Lower Molding - Ford (BB5Z-7803144-BA)
And potentially the clips, but some people say the clips came with the parts (???) which say they are left and I cannot find a right part number? BB5Z-78519R44-A
Can somebody who has done this replacement confirm the parts come with the weatherstripping? This seems like such a trivial part to take it to Ford over, but the parts diagrams are really iffy about whether the stripping is included or not.
Using the 'Search' feature I found and merged your thread with this one. There are several posts on this issue of the moulding coming off.So...a gust of wind just ripped this panel off my 2018 XLT on the highway. Is this a user replaceable part with moderate skills, and does anybody happen to know A) the part number and B) how it comes off (is it just the visible bolts?)?
Welcome to the Forum.Add me to the list......I've now lost both A Pillar covers (driver side and passenger side). After reading through this forum, I'm going to not get it dealer repaired at my cost (i'm now into extended warranty coverage, which after reading here, seems to not be covered). I've also had the left roof rack cover come loose, so that is project #2 to tackle assuming it is not covered either....... *edit* The roof rack cover issue is covered, just called in for service (oil change, AC check, and there is a service advisory for loose roof rack covers).
Thanks for the welcome -
I realized your questions for the previous poster were never answered - it seems like the weather strip adheres to the underside of the plastic moulding. When I pre-fit the piece there is a gap between the edge of the plastic and the windshield - where this rubber piece is to go.
I have looked into weather stripping options and found this marvelous image from AliExpress - but it seems any option I find on amazon is more "foamy" and meant for inside doors or other areas and not that direct contact with wind/rain/weather...the surviving side is definitely rubber and not foamy.. View attachment 163663
On the good side - I have been driving for about three weeks now without moulding in place - an no leaks.
Welcome to the Forum.My wife was driving in a terrible wind storm and the a pillar trim blew off. I bought the inner piece (bracket) and outer trim piece at the dealership. Is it required to replace the bracket or can I use just the outer piece? I'm concerned that the clips may not be strong and that's why it came off. Any one have experience in this repair? It's a 2016 Explorer XLT. thanks, moday
I just bought a 2017 explorer platinum trim used and noticed that the top portion of the outer trim was not flush. I called my local ford dealer for an appointment at 715am on 5/26/22 and when I got there they advised that it might be a day or 2 to get the parts. I said I already called the parts dept and they are in stock. They then stated that they would need the vehicle a day to get this replaced. What is an appointment for if you cant work on it until next day. Unsure why I thought they would do it on the spot but I just bought the parts and went home to install. Took 30-45 minutes to install and good as new now.Hi guys,
Anyone knows part number / name fo this part?
Cannot find it (searched for all body schemas on exterior parts).
It is explorer 2017
Thanks for helping
How much were the parts if you dont mind my asking.I just bought a 2017 explorer platinum trim used and noticed that the top portion of the outer trim was not flush. I called my local ford dealer for an appointment at 715am on 5/26/22 and when I got there they advised that it might be a day or 2 to get the parts. I said I already called the parts dept and they are in stock. They then stated that they would need the vehicle a day to get this replaced. What is an appointment for if you cant work on it until next day. Unsure why I thought they would do it on the spot but I just bought the parts and went home to install. Took 30-45 minutes to install and good as new now.
Welcome to the Forum.I just bought a 2017 explorer platinum trim used and noticed that the top portion of the outer trim was not flush. I called my local ford dealer for an appointment at 715am on 5/26/22 and when I got there they advised that it might be a day or 2 to get the parts. I said I already called the parts dept and they are in stock. They then stated that they would need the vehicle a day to get this replaced. What is an appointment for if you cant work on it until next day. Unsure why I thought they would do it on the spot but I just bought the parts and went home to install. Took 30-45 minutes to install and good as new now.
Have a look at this; Glass, Windows & Related Components for 2011 Ford Explorer | Genuine Ford Auto PartsHow much were the parts if you dont mind my asking.
