handgun
- October 20, 2010
- Grand Rapids MI
- 1998 Explorer
For those of you that have probably wasted money troubleshooting and ultimately purchased a new wiper rear motor, I may have the answer.
If you have determined that your rear wiper motor is getting the proper voltage, (fuse, relays and switch are OK), try this. My second wiper motor stopped working despite knowing the proper voltage is making the trip to the motor. It "clicked" and the relays in the fuse box under hood cycled, although the drive shaft on the wiper motor did not move.
I removed the unit from the rear door and removed the black plastic shaft housing collar. I sprayed WD-40 into the shaft housing three times and let it soak for about 30 minutes. I then applied heat from a propane torch very carefully, just to warm the housing and shaft. (Be careful WD-40 is flammable). This expands the metal and releases the corrosion bind. To my amazement, after reinstalling, it now works!!!
Conclusion: water infiltrates the drive shaft housing because it is canted upward. Water and minerals corrode the cheap pot metal housing and the drive shaft due to galvanic reaction (dissimilar metals). Keep the shaft lubricated with a water-displacing product, then buy yourself a premium adult beverage with the money you saved!
