- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2025 Aviator Reserve 201A
- Callsign
- VE3... grid FN25hg
My questions are:
1. Are the main lights that come with the 2013 Sport considered HID's?
2. If not, is there an HID kit for the mains and fogs?
3. What temperature are the stock mains and fogs?
4. Whats the difference between Xenon and HID?
1. No they are not HID they are Halogen.
2. There are aftermarket HID kits available. There are threads in the Modified section of this Forum regarding that. If you want the fogs to operate as intended, you would not want HID lighting since it would be too bright. If you want to buy the Ford HID lamps I believe you're looking at well over $1000 each.
3. Not sure on that one. I assume you are talking about the HID lamps on the Limited. The brightest light from HID's is in the 4300 K range.
The higher the temp the more blue it appears and produces less light.
4. Xenon/Halogen uses a filament and gas to produce light while HID uses a high voltage to produce an arc that provides the light.
Much of this info can be found on the Internet.
