ext. rear brake hose? | Ford Explorer Forums - Serious Explorations
CheapThrillEX
Middleville, MI (Gun Lake)
93 Explorer Sport
i got an 8.8 with disck brakes from an 96 Explorer, the axle and brakes are on my bronco 2 (approx 6-8"s of lift)
and the drivers side hose is at its max at stand still, you know the driverside shares the left caliper hose and splits off with hard line to the right hose
anybody make an ext. hose?
superlift, or take it to a custom hose shop. Mine were done in 10 min while I waited for $50. Both front lines extended 12"
but i need the rear hose not the front.............i was hoping somebody knwe of a stock type hose that would work that is longer........in a serious $$ crunch on this project
6
With the $$ constrains you have, I think the easiest (though time consuming) solution would be to take that hose off and spend a few hours at the junk yard looking under all Fords to see if you can find a longer one with matching fittings.
front or rear, it dosent matter. Superlift makes extended rear ones.
