wollimann
- July 19, 2011
- Location
- Europe Germany
- Europe (Germany)
- 1997 4.0 sohc xlt
In my case the stiff torson bars were screwed up to compansate the higher rear with longer shakleswhy would you need extended length cv axles?
and add-a-leaf springs.
(do not have the $$$ for longer travel suspension)
Yes, for the stock high suspension the OEM axles are good and they work fine in their "comfort zone".
If the front is screwed up the OEM axles will fail much sooner, not the boots will fail
but the inner tripode joints.
I hoped the the greater angles of these TrakMotive axles will meet my requirements.
I think they did until now, only the outer boots fail.
As TrakMotive support told me today:
"These axles are not made to be taken apart so I cannot give you any info as to how to replace or remove any piece of the axle."
That must be the reason the joint puller brake off.
The new boot spreader SKF VKN 402 is great, but the soft silicone boots were disrupted
while spreading.
Now i have to look for other spreadable boots.
Wolfgang
