Fiberglass Whats Your Ideal Setup? | Ford Explorer Forums
rkalb
ElecExplorer
Nevada City, CA
2000 XLT AWD,1996 XLT 4x4
What do you think of one piece fiberglass front ends?
Pictured in a 3 Piece w/ no scoop or louvers
http://www.mcneilracinginc.com/off-road-fiberglass/Ford/Explorer/95-01_4dr/index.htm
And what do you think of the Sport Trac Conversion in a one piece or a 3 piece?
One Piece
http://www.mcneilracinginc.com/off-road-fiberglass/Ford/Explorer/one-piece-front-end/index.htm#
3 Piece
http://www.mcneilracinginc.com/off-...Explorer/95-01_4dr/05SportTracConv/index.htm#
and does anybody know how to build a hinge for the one-piece?
So whats your ideal setup?
There is also www.fiberwerx.com
Im going to be running a 1 piece just because its easier for me. But unless you have a full engine cage is say dont do it. They need quite a few mounting points to keep them stable. Just get a good set of fenders and bolt them up. Its pretty easy too.
carlover is that your explorer on the BTF Website? Which one piece are you gonna run? Im just having a hard time choosing what to get.
i am purchasing the dixon bros kit for 4wd so yeah wider than stock
get the fiberwerx 6" flare then. or another company makes a wider 8" flare, i used to run thier glass and its the best looking out there. Company is called Baker motorsports, look them up.
i will probably run the mcneil sport trac trophy 10" flare one peice if the expo and 01 and up ST share the same door lines.
