For all guys with a trimmed engine crossmember | Ford Explorer Forums
Burns
Moderator Emeritus
Pulaski, TN
1991 Explorer/2002 F-250
When I did my SAS I trimmed the engine crossmember just to make sure the diff was not going to hit it.
Then end result after almost 3yrs is a cracked front crossmember.
Its in the process of getting welded back together but this is just a reminder to check stuff like this.
whats that from ? looks like you got a substancial leak going on there on the right hand side .
im sorry I cant see the crack, where are we talking exactly? LOL
Plate that sucker from behind the FULL WIDTH of the x member
After you trimmed it, did it need it?
That why I just cut mine out completly! :p:
It does not get close. We thought it did and went ahead.
I want to pull it out and build another crossmember but that takes more time than i have right now.
Its been welded back and front. I may plate it soon over the crack.
I know its getting worse and worse. Valve cover gasket and i think i may have another leak up there. Gonna tear into that someday
if you plate the crack a new crack will appear on the side of the plate, its murphy's law
I would plate it from in front or from the back the full length or gusset it for strength like Rock Ranger did
Ok ill give his a search tonight and check it out. Thanks
That is a case of a stress riser -- I would have smoothed out the cut in the beginning and maybe filled in that hole.
But why not just make a new cross member like the one Section525 made? Its fairly easy and would be a lot stronger than the stock.
Thats my plan. We didnt have the time when i did that so it survived. Its been welded up crack and hold and im gonna try to get it smoothed out tomm.
