- August 1, 2008
- MO MO
- 94 & 95 XLT's
Been racking my brain trying to figure out the VSS issue.
I can use a little help here and put to me in Layman's terms if at all possible.
First off I need to go back over whats done to what so far.
The working VSS is plugged into the 95 manual harness.
The 95 manual harness is plugged into the 95 auto engine harness on the pass side 16 pin connector.
The 95 manual ECM is NOT reading the signal from the VSS.
I have gone over some sites that have the diagrams for a 95 ECM pin out.
Pin #3 is the VSS 679 GY/BK (+) side.
Pin #6 is the VSS 676 PK/O (-) side.
Here is the pin out on the ECM.
This is the manual trans harness diagram. VSS is pin #'s 12 & 16.
This is the auto trans harness diagram. VSS is pin #'s 5 & 6.
There are other wires in the #5 & 6 slots needed for the VSS.Here is where I get lost. I need help in placing the pins in the right spots. There is a shuffle here like a rubiks cube and I freeze up every time I try to figure this out. The engine harness is the female, and the trans harness is the male. I need the male end of the manual to go to the female of the auto correctly.
329 (pk) is the wire in the #5 spot and goes to the start signal feed in the CPP which is jumped at the other end.
570 in the #6 spot is a power ground. Switch to #11?
Remove (32) and replace with #5? Just cut (32) off?
So, if I am thinking this thru right,
VSS
#12m to #5a
#16m to #6a
#6m to #11a
Discard #5a (329)?
HO2
#2m to #4a
#4m to?????
Can someone tell me if I have this right? Also if you see anything else that needs to be shuffled around, please let me know as I have no reverse lights
Thanks in advance!
BTW......
Here is an ALLDATA link, with every single wire connector diagram, schematic, vacuum routing, circuit pathways, on a 95 EX.
http://www.scribd.com/doc/10112665/95-Explorer-Diagrams
VSS
#12m to #5a
#16m to #6a
#6m to #11a
Discard #5a (329)?
HO2
#2m to #4a
#4m to?????
Thanks in advance!
BTW......
