- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Bouncing Smiley = fixed?
Nope, it means that he would like to stomp on it.:
There was a moment there--let's just say I was frustrated--
Well,
I finally got some firewood together and got my lazy butt out to look at this thing--
First was to drain the fuel-ummm-oil from the oilpan, changed filter.
While my oil cap was off, I connected my remote start switch in place of the starter relay and bumped it--thr rocker arms moved, so the timing chain is not broken.
I removed #5 spark plug, installed my compression test guage, cranked it, cold and washed was 190 psi---
hmmm? so I removed the fuel pump relay, turned key to on, hooked my timing light up and it indicated spark, which was also on time. hmmm?
I then emptied my bad oil back into the 5 qt jug--it is full and I have about a quart still in pan--it was very thin, and gassy smelling--a small amount thrown into my woodstove went FOOOM!
hmmm?
For giggles, I replaced the relays, turned the key and she fired right up---
All I did was change the oil!!!!!![]()
Why?????
The only thing I can figure-is the oil was washed from the previous fuel pump issue-causing it to be too thin to satisfy the oil pressure sender--doesn't this cut the ignition or something?
I wish I would have learned something here--or worse-maybe I will.
Besides a small coolant leak on my heater core hose (fixed I think) there are no problems. No CEL--runs fine and smooth--
I change my oil often---in fact this oil had maybe 1000 miles on it
JT I was all around it with check the coil and wiring to the coil.
I have a question?
I have an Aeromotive bypass style fuel pressure regulator, fuel rails and 42lb injectors--
I have asked this before, and was told, my regulator allows the fuel pressure to drop, once the engine is shut off--
Reason I ask--it always has--since 2004, when I first ran this engine.
I turn off engine-fuel pressure drops to 0.
I am certain I have no fuel leaks
Is this normal, or am I on to something here??
injector leaking????? If this is so, it has been happening since they were new--
How to be sure?
Rocket-don't forget to note(because we know how people take simple words out of context)that the regulator will bleed off in a return style system but only after a certain amount of time. Now this time is generally noted in the factory specs. If it(pressure) immediately zero's when the key is shut off then you either have a bad injector(s) or a fuel pressure regulator. When you have a bad regulator or injectors more than the pressure is bled off you bleed fuel so everytime you startup you will have to reprime the system hence...longer cranking before startup.
