aldive
Elite In Memoriam
- January 17, 2001
- 1999 XLT
A/F test results
I wanted to determine the A/F ratio while using HHO in my truck (1) at idle (2) 65 MPH highway cruise and (3) WOT ( short burst only ). I have this data from a previous test of this particular PCM tune without using HHO for a comparison.
Note: this PCM tune is forcing closed loop operation from start up and has a good delay before switching to open loop at WOT. This explains why the WOT readings are what they are. In the short run at WOT, the trucked stayed in closed loop.
Without HHO:
(1) Idle – 14.7
(2) Highway cruise 65 MPH – 14.7
(3) WOT – 14.7
All of the above readings are rock steady
With HHO running
(1) Idle – 14.5-14.6
(2) Highway cruise at 65 MPH – 14.4-14.6
(3) WOT – 14.4-14.5
All speeds GPS determined. All air/fuel ratio data determined by using an Innovate Motorsports wideband LM-1 A/F meter (http://www.innovatemotorsports.com/products/lm1.php ). The operation state ( closed/open loop ) was determined by OBD II scanner.
Without HHO:
(1) Idle – 14.7
(3) WOT – 14.7
With HHO running
(3) WOT – 14.4-14.5
