Motoarzan
- May 25, 2013
- Cambridge, Ontario
- Explorer Sport 2014
Hi All.
I finally installed my HID kit today and thought I'd post some step by step pics. I installed these on my 2014 Explorer Sport.
I purchased the Coolbulbs kit with the newer electronic ballasts and 6000k color temperature. Part# G1K-9005. I picked these because after all my forum research they seemed to be the ones that nobody had any issues with and got great customer service. These ones also don't require any special time delay relay and they are all plug and play and relatively easy to install. The ballasts themselves are also fairly small and compact.
Please note. The passenger side is easy, the driver side is a pain in the [MENTION=127576]ss[/MENTION] and has little room to get at it. You might require the help of your wife, daughter or someone else with small hands to get that bulb out.
STEP#1. FIRST OFF - IF YOU'RE A CANADIAN. GET YOU DEALER TO PROGRAM YOUR DRL'S TO BE ON THE YELLOW MARKER LIGHTS INSTEAD OF YOUR HEADLIGHTS. IF YOU DON'T YOU MAY HAVE PROBLEMS WITH YOUR HID'S AND CERTAINLY REDUCED LONGEVITY BEING ON ALL THE TIME. THE PROGRAMMING IS A SIMPLY TASK BY A TECHNICIAN CONNECTING A LAPTOP TO THE VEHICLE AND YES, IT CAN BE DONE. SEE OTHER THREADS ON THE INSTRUCTIONS FOR THIS.
OH, AND IF YOU'RE CANADIAN DON'T FORGET TO START WITH A TIM HORTON'S COFFEE. ESPECIALLY WHEN IT IS -1 DEG. CELCIUS WHERE I AM TODAY. FOR THE AMERICAN FOLKS YOU MAY WANT TO CHOOSE A DUNKIN DONUTS OR STARBUCKS
LOCATE THE DUST COVER AND REMOVE.
START CUTTING A SMALL HOLE IN THE BOOT
TRIM IT LARGER AND LARGER UNTIL THE DESIRED SIZE IS ACHIEVED.
LAY OUT YOU COOL BULB KIT ONLY ONE SIDE BULB AND BALLAST FOR NOW.
FEED WIRES THROUGH CUT OUT HOLE IN BOOT. NOTICE THE DIRECTION THE BOOT IS FACING IN RELATION TO THE BULB SIDE.
WORK THE RUBBER GROMMET PART OF THE WIRE HARNESS INTO AND OVER YOUR HOLE TO MAKE A PERFECT SEAL.
LOCATE THE BULB IN THE HOUSING BEHIND THE RUBBER BOOT. DISCONNECT THE CONNECTOR FROM THE BULB, ROTATE 90 DEGREES. AND REMOVE. ON THE DRIVER SIDE, THIS IS WHERE YOU MIGHT NEED HELP WITH SOME LITTLE HANDS.
THE CONNECTOR WILL BE SOMEWHAT RECESSED DOWN BELOW BUTT ONCE THE BULB IS OUT YOU CAN PULL IT UP AND OUT A BIT AS SHOWN IN PIC BELOW.
CONNECT HID HARNESS/CONNECTOR TO THE CONNECTOR THAT WAS ORIGINALLY ATTACHED THE THE FACTORY BULB.
REMOVE BULB FROM PROTECTIVE CLEAR COVER AND INSTALL INTO HOUSING. PUSH IN AND ROTATE BACK 90DEG TO SECURE IT. MAKE SURE TO PUT EACH BULB INTO THE HOUSING IN THE SAME ORIENTATION. I INSERTED IT SO THAT ONCE ROTATED INTO POSITION THE GLASS PART OF THE BULB WOULD BE AT THE TOP. I FIGURE THIS MIGHT LOWER THE CUT-OFF, OF THE BEAM THROUGH THE PROJECTOR.
TUCK WIRES AND CONNECTOR BACK INTO HOUSING AND PUT BOOT BACK ON. YOU CAN ALSO SLIDE THE INDIVIDUAL WIRES THOUGH THE GROMMET TO REDUCE THE SLACK AND TIGHTEN THEM UP.
NOW. CONNECT THE 3 REMAINING CONNECTORS TO THE BALLAST AND IGNITER.
NOW. REPEAT ALL THE ABOVE STEPS FOR THE OTHER SIDE LIGHT.
ALSO DON'T ZIP TIE ALL THE WIRES AND TUCK AWAY THE BALLASTS YET. LEAVE THEM SITTING AND FIRST TURN ON AND TEST THAT THE LIGHTS WORK. IF THEY DON'T CHANCES ARE YOU HAVE A POLARITY ISSUE. MINE DID!! SIMPLY TURN THE CONNECTOR AROUND.
NOTICE THE NOTCH ON THE TOP, AND THE HOOK ON THE BOTTOM OF THE CONNECTORS. I TURNED THEM AROUND TO CHANGE THE POLARITY (THE CONNECTORS WILL STILL MATE IN REVERSE ORIENTATION, YOU JUST WON'T HAVE THE NOTCH AND HOOK LOCKED TOGETHER BECAUSE THEY'RE ON OPPOSITE SIDES NOW). I ONLY DID THIS BECAUSE I WAS TOO LAZY TO REMOVE AND SWITCH THE INDIVIDUAL PINS IN BODY OF THE CONNECTOR.
EVEN THOUGH THE CONNECTOR IS REVERSED AND NO NOTCH AND HOOK HOLDING THEM TOGETHER THEY ARE STILL PRETTY SNUG. I SIMPLY WRAPPED THE WHOLE CONNECTION IN ELECTRICAL TAPE TO BE SURE THEY ARE SECURE.
CHECK THAT YOUR LIGHTS WORK NOW. YES!!!
NOW YOU CAN THINK ABOUT TUCKING AWAY THE BALLAST IGNITER AND CABLES. CLEAN THE AREA WHERE YOU WILL STICK YOUR BALLAST WITH ALCOHOL. I CHOSE HERE!
ATTACH PROVIDED 3M TAPE TO BALLAST.
ATTACH 3M TAPE TO IGNITER. I PICKED THIS STUFF UP AT AN AUTOMOTIVE STORE.
THIS IS HOW AND WHERE I STUCK MINE ON DRIVER SIDE.
AND, PASSENGER SIDE SIMILAR.
PUT YOUR FACTORY BULBS BACK IN THE HID BULB COVERS FOR BACKUP.
ENJOY YOUR LIGHTS. THESE ARE AWESOME AND I LOVE THE CRISP 6000K COLOR. WAY, WAY BRIGHTER AND WHITER THAN STOCK.
