  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Homemade safari rack mouting question
kstrayhorn
Landmark, Little Rock, AR
'02 XLT
So i am making my own safari rak. My problem at the moment is the mount to the roof rack. With the materials i have now ot would be easiest if i could mount it vertically straight up And down like the 2nd gen roof racks are instead of horizontally like my third gen rack is. So if i got a gen 2 rack would it be directly compatible with my gen 3 explorer?
Thanks in advance,
Kendal
kstrayhorn
'02 XLT
Nobody knows??? I figured somebody would have to know about this kind of thing.
kstrayhorn
'02 XLT
I must have worded the title badly, I'll try again with another title...
celly
disturber of the peace
calgary
99 eb 5.0 awd
Multiple posts on the same topic is bad forum etiquette. Also expecting an answer right away is as well. Hang tight. Someone will answer.
kstrayhorn
'02 XLT
Sorry I just wanted an answer before the junkyard closed today but I'll wait now.
celly
calgary
99 eb 5.0 awd
Try searching the archives. Site has been in existence for a long time.
Posted via Mobile Device
David in NC
North Carolina
'97 XLT
I have a 2nd gen rack if you need one, but I don't know about compatibility.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Threads merged.
kstrayhorn
'02 XLT
Thanks, IZ, and Celly, I will do that right now!! Somehow I keep forgetting about the search feature...
And David, thanks for the offer, but I am going to go down to the salvage yard, which is literally 1 block from my house either today or this weekend and take some measurements to see if they will work. I would take you up on it, except that I fear shipping will be outrageous.
I will be sure to post the results of my research!
Sorry for any trouble I caused, Iz.
Kendal
EasyRhino
Kailua, Hawai'i
'02 Limited 4.6L 4x4
Not sure I understand your question, but I had a 2nd gen and now have a third gen and the roof racks stricke me as entirely different, however, my memory may be off on this item.
I would be interested in seeing pics of your Ex when you are done, should be interesting.
C Homemade transmission fill adapter. Stock 2002 - 2005 Explorers 1
Reklaw Inner Tie Rod Boot Loose / Rack and Pinion Stock 2002 - 2005 Explorers 0
C Roof rack plastic yellow thingies? Stock 2002 - 2005 Explorers 1
M Looking for Rack and pinion frame bolts Stock 2002 - 2005 Explorers 1
R 03 Explorer V8 steering rack Stock 2002 - 2005 Explorers 2
S Anyone know where I can find instrux or pics of installing OEM cross bars to my 04 roof rack? Stock 2002 - 2005 Explorers 1
N 3rd gen roof rack ?s Stock 2002 - 2005 Explorers 4
Exproblems Roof Rack Removal on a 2005 Ford Explorer Stock 2002 - 2005 Explorers 4
N 2002 Rack and Pinion Removal Stock 2002 - 2005 Explorers 8
J 2002 4.0L Rack and pinion replacement? Stock 2002 - 2005 Explorers 7
P 2002 roof rack repaint Stock 2002 - 2005 Explorers 2
D '05 roof rack crossbars Stock 2002 - 2005 Explorers 11
C Another stock roof rack question.... Stock 2002 - 2005 Explorers 1
C Steering shaft from firewall to rack and pinion bad?? Stock 2002 - 2005 Explorers 5
C 2005 Explorer Roof Rack Removal Stock 2002 - 2005 Explorers 1
D Removing roof rack Stock 2002 - 2005 Explorers 11
C Help me identify the missing pieces to my roof rack Stock 2002 - 2005 Explorers 3
P Rebuild steering rack? Stock 2002 - 2005 Explorers 0
T What rack&pinion do i have? Stock 2002 - 2005 Explorers 2
G steering rack and shaft issue Stock 2002 - 2005 Explorers 1
S Rack and pinion symptoms Stock 2002 - 2005 Explorers 7
R Rack and pinion leak Stock 2002 - 2005 Explorers 1
E Rack and Pinion Replacement Stock 2002 - 2005 Explorers 1
BigRondo Painting Roof Rack Stock 2002 - 2005 Explorers 6
macboney Roof Rack part needed Stock 2002 - 2005 Explorers 1
N Rack and Pinion Problems and a chirping sound... Stock 2002 - 2005 Explorers 1
J Roof rack cross bars Stock 2002 - 2005 Explorers 1
2 2005 rack & pinion leak Stock 2002 - 2005 Explorers 0
K Roof Rack Removal Help Stock 2002 - 2005 Explorers 2
P rack and pinion question Stock 2002 - 2005 Explorers 2
L Roof Rack cross bars Stock 2002 - 2005 Explorers 7
R Has anyone here worked on a Exp steering rack? Stock 2002 - 2005 Explorers 2
R Rack & Pinion or air in system? Stock 2002 - 2005 Explorers 13
J Tighten down roof rack Stock 2002 - 2005 Explorers 2
X Leak in roof rack Stock 2002 - 2005 Explorers 4
P Luggage Rack question Stock 2002 - 2005 Explorers 3
O First Post, Question about roof rack/lighting Stock 2002 - 2005 Explorers 1
S Roof Rack & Antenna removal Stock 2002 - 2005 Explorers 5
S Steering Rack Leak Stock 2002 - 2005 Explorers 0
JW Limited roof rack Stock 2002 - 2005 Explorers 5
J steering rack replacement Stock 2002 - 2005 Explorers 0
C Tow hook question/roof rack Stock 2002 - 2005 Explorers 16
E '05 Rack and Pinion problems. Stock 2002 - 2005 Explorers 2
B Any body have pics without a lugage rack Stock 2002 - 2005 Explorers 0
B Howto remove luggage rack in a 02 Stock 2002 - 2005 Explorers 9
S Rack with canopy Stock 2002 - 2005 Explorers 0
B roof rack cross bars Stock 2002 - 2005 Explorers 1
S Stock 3rd class hitch capacity - rack? Stock 2002 - 2005 Explorers 5
B Removing Cargo Rack? Stock 2002 - 2005 Explorers 2
TFCeddieB Roof Rack Question Stock 2002 - 2005 Explorers 2
Similar threads
