How many miles on your 2ND GEN EX?
Steve Wendling
Location
Tucson Arizona
Tucson, AZ
1998 Explorer XLT
28,900 on 1998 XLT. 2nd owner. Original owner bought new at age 65 and didnt drive it much.
ThreeJs
Las Vegas/Henderson NV
96 EB Explorer 4x4
When I left the house this morning...
S How many miles without having to rebuild engine, tranny, transfer ca Stock 1995 - 2001 Explorers 10
T How many miles has your Timing Chain Rattled Stock 1995 - 2001 Explorers 25
S How many miles on your 5.0? Stock 1995 - 2001 Explorers 10
A How many miles with the rattle? Stock 1995 - 2001 Explorers 13
T Hey guys how many miles are you getting on a full tank? Stock 1995 - 2001 Explorers 37
C How many miles do you have Stock 1995 - 2001 Explorers 66
M How many miles do you all have? Stock 1995 - 2001 Explorers 26
Z QUestion about Longevity of the SOHC motor and Explorers in general..how many miles Stock 1995 - 2001 Explorers 20
cjryan How many miles? Stock 1995 - 2001 Explorers 74
P How many miles?? Stock 1995 - 2001 Explorers 54
C How many miles to expect Stock 1995 - 2001 Explorers 13
D How Many Miles to a Tank? Stock 1995 - 2001 Explorers 44
B O2 Sensors - How many? Where? Stock 1995 - 2001 Explorers 2
koda2000 How many tools does it take to add oil to the rear diff? Stock 1995 - 2001 Explorers 30
A Which tire ? How many to change ? Stock 1995 - 2001 Explorers 10
S How many o rings for a power steering pump? Stock 1995 - 2001 Explorers 0
E new to me 1996 explorer from grandma ignition issues , many parts changed Stock 1995 - 2001 Explorers 112
E Too many misfires, and that's just the begining of my tale of woe Stock 1995 - 2001 Explorers 15
B HOW MANY TURNS OF THE TIE ROD? -0.32 Degrees Total Toe Stock 1995 - 2001 Explorers 0
Z How many U Joints do I have? Part numbers? Stock 1995 - 2001 Explorers 2
koda2000 How many tools does it take? Stock 1995 - 2001 Explorers 20
C Help! Probably an easy one > How many O2 Sensors? Stock 1995 - 2001 Explorers 5
J Tires oversize, too many changes in MPG and speedmeter? Stock 1995 - 2001 Explorers 6
A Many ABS Codes Stock 1995 - 2001 Explorers 1
P How many Gen IIs do you see a day? Stock 1995 - 2001 Explorers 24
C How many catalytic converters? Stock 1995 - 2001 Explorers 9
G how many rpms at a stop light Stock 1995 - 2001 Explorers 8
L Curious to know how many people do this... Stock 1995 - 2001 Explorers 21
I many issues Stock 1995 - 2001 Explorers 0
A How many psi should the fuel pump give? Stock 1995 - 2001 Explorers 10
E Am I asking too many questions? Stock 1995 - 2001 Explorers 6
M Bank 1 Sensor 1 on SOHC 00 Eddie Bauer is it Driver or passenger?! Did many searches Stock 1995 - 2001 Explorers 5
C How many Horns? Stock 1995 - 2001 Explorers 9
J how many quarts of oil for a differential fluid change Stock 1995 - 2001 Explorers 4
L '99 EX Inst Panel - How many bulbs? Stock 1995 - 2001 Explorers 14
S How many shades of Red in 1998...Explorer & Mounty Stock 1995 - 2001 Explorers 4
J How many more quarts of ATF do I need to add?!?! Stock 1995 - 2001 Explorers 17
S How many 194 bulbs are on a 95 explorer dash? Stock 1995 - 2001 Explorers 6
C A great many questions about replacing brake system Stock 1995 - 2001 Explorers 5
G Many Thanks for hub replacement advice Stock 1995 - 2001 Explorers 0
B So many issues - just one post :) Stock 1995 - 2001 Explorers 8
J How many 2nd gen V8 AWDs were built? Stock 1995 - 2001 Explorers 8
soon2bsick how many o2 sensors? Stock 1995 - 2001 Explorers 9
D Heat and AC fine, air coming out to many vents. Stock 1995 - 2001 Explorers 4
4 how many #'s are my injectors? Stock 1995 - 2001 Explorers 0
J How many quarts of ATF fluid? Stock 1995 - 2001 Explorers 1
Dennis1188 How I replaced my power steering pump-many photos. Stock 1995 - 2001 Explorers 24
Dennis1188 Total Color Change-Interior and Exterior-Many Photos Stock 1995 - 2001 Explorers 44
D How many cans of 134A it takes? Stock 1995 - 2001 Explorers 3
S (many problems) speedometer, o/d light, fuel pump relay/ignition switch Stock 1995 - 2001 Explorers 0
Similar threads
